Old 01-25-2012, 02:40 AM   #1
coreyslude
Porterbuilt control arms on stock crossmember?
Does anyone have Porterbuilt control arms setup for coil springs and with the one inch forward option on the ball joints? On a stock crossmember? Seems like it would be comparable to the Hotchkis arms.
coreyslude is offline   Reply With Quote
Old 01-25-2012, 03:57 AM   #2
andrewmp6
Re: Porterbuilt control arms on stock crossmember?
I'm not sure just wait for nate he will answer when he sees this.
andrewmp6 is offline   Reply With Quote
Old 01-25-2012, 08:59 AM   #3
Bennett68C10
Bennett68C10's Avatar
I just ordered mine for a stock crossmember with the ball joints moved forward 1" but mine are for airbags not coils. Like andrewmp6 said Nate will be able to answer all your questions. He's got great customer service and really helped me out on mine.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-25-2012, 11:21 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
What specific information are you looking for?
The lower control arm is compatible with coil-springs or an air spring (for the coils we include a billet spring retainer that bolts onto the arm... it can be removed and bags can be used if desired).
On the factory front end we tested, the static castor was 2.6 degrees and through a total of 4 inches of travel (2 inches of compression (bump) and 2 inches of extension (droop) the most castor we saw was a whopping 2.72 degrees.
When running our forward arms, you will gain up to an additional 5 degrees of castor. If that's not enough, we can leave the upper arm in our "standard" dimension and combine it with the lower forward arm, and you will be able to gain another couple degrees.
We sell the arms as a pair, or can seperate them as well.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-25-2012, 01:58 PM   #5
coreyslude
Nate
That's pretty much what i was looking for. From what i've read sounds like the extra castor really helps these trucks handle. Maybe tax time i can order a set. Thanks for the response.
Old 01-25-2012, 02:08 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
You are correct, the extra castor makes a big difference.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-25-2012, 08:52 PM   #7
coreyslude
Will I need to do any modifications to install these? I think I'm going to go with the cpp modular spindles, drop springs, and sway bar. Will the cpp sway bar work with the porterbuilt lowers? Just trying to make sure I have everything covered. Thanks in advance.
Old 01-26-2012, 12:14 AM   #8
PBFAB.COM
PBFAB.COM's Avatar
I have not installed a CPP sway bar, and am unsure of its dimensions. We have a sway bar that fits, and I also know the muscle bar will fit. Our bar is normally priced a little higher than CPPs, but we can make a package deal to where the difference is absorbed. The spindles and drop springs will fit just fine. We use a larger cross-shaft on the upper arm, and I have had a couple customers tell me they needed to slightly clearance the little gusset on the upper control arm mount portion of the coss-member. Not a big deal... but something to be aware of.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-12-2015, 10:39 PM   #9
ol_skool_chevy
ol_skool_chevy's Avatar
how can I find more information on ordering uppers first and lower later?....and cost
I have never seen them listed that way
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 11-13-2015, 10:13 AM   #10
PBFAB.COM
PBFAB.COM's Avatar
Just shoot us an email and we will get back to you with some pricing!
Sales@pbfab.com
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 12-26-2021, 06:13 PM   #11
Beckett88
I know this is a old post but can you use your stock steering component?
Beckett88 is offline   Reply With Quote
Old 12-31-2021, 02:00 AM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
Yes
Keith
Convert to disc brakes.
