Old 01-25-2012, 10:04 AM   #1
68Stepbed
68Stepbed's Avatar
adapter plates?
I've done a little research, but I just can't seem to decide with adapter plates I should go with.
I plan to install my LS1 in the 6-cyl position and get it as far back as I can without having to fabricate my own mounts. Most mounts I've seen still move the engine forward though.
Who has mounted their LS engine this way?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-25-2012, 10:16 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: adapter plates?
I tried getting mine back there(6cyl+1"set back plates), but my 4l80E hit the cab pinch weld. It may clear with a high hump.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-25-2012, 10:26 AM   #3
68Stepbed
68Stepbed's Avatar
Re: adapter plates?
I'm gonna stay with my TH350 for the time being, so I should have sme wiggle room.
Matt
Old 01-25-2012, 12:27 PM   #4
Shon
Re: adapter plates?
have you looked at DirtyDingo.com, they have some adjustable adaptor plates.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 01-25-2012, 01:12 PM   #5
69trk
69trk's Avatar
Re: adapter plates?
I just ordered some of dirtydingo's motormounts.. adj. up to 2"
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 01-25-2012, 01:16 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: adapter plates?
mount adapter plates (I used transdapt) + I6 perches in the rear position put me almost INTO the fire wall. So far back that my rear coil packs did not clear. I had to move it forward over 1.5" to get it where i liked it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-25-2012, 04:05 PM   #7
68Stepbed
68Stepbed's Avatar
Re: adapter plates?
I like the Dirty Dingo adapters. I'll probably order a set of them when I order.
Matt
Old 01-25-2012, 08:56 PM   #8
paul mora
Re: adapter plates?
CPP has system that includes a adjustable mount theyntold me on then phone yesterday it includes the perches for just a little mone then the Dingo
Pulatoy
paul mora is offline   Reply With Quote
Old 01-26-2012, 09:26 AM   #9
68Stepbed
68Stepbed's Avatar
Re: adapter plates?
Thanks for the info, Paul, but I had a less than desireable dealing with CPP a few years ago which I just can't seem to get over. I just have a hard time dealing with them at all.
Matt
Old 01-26-2012, 01:39 PM   #10
paul mora
Re: adapter plates?
Yesterday I ordered the ECE system they said I could use my low mount air and factory exhaust with a slight mod. Stan gave a grat deal and said to call with any problems or if need help
Pulatoy
Old 01-26-2012, 02:41 PM   #11
shearjs
shearjs's Avatar
Re: adapter plates?
When I first threw around the idea of putting an LS in my 70 GMC, I found the CPP Perches and Adapter Plate combo through classicparts.com and decided to go with that. Using those products together, I had to mount my perches in the rear holes and drill a new hole in the crossmember for the lower connection. This put the engine in a location where my oil pan cleared the crossmember and the intake didn't hit the firewall. My problem arose when I couldn't get my Doug Thorley LS swap headers to clear the engine perches. I found some 3/8" steel plate and decided to make some new adapter plates based on some info posted from gLock35icsp in this post:
http://67-72chevytrucks.com/vboard/s...49&postcount=5
The adapter plate I had that came with the kit was #3. I made some plates to resemble #1, so hopefully I can move the perches back to the front location, and leave the engine roughly in the same location, in regards to the crossmember, as it was with the plates in #3. This should allow the headers to clear, and hopefully find a final resting spot for my engine. Hope this helps.
shearjs is offline   Reply With Quote
Old 01-26-2012, 08:15 PM   #12
6.0 1955
Re: adapter plates?
I used 6cyl position perches with adapter plate #2 and it fits about as close to the firewall as possible. Also used th350 and no cutting necassary for it to fit. Good luck with the build.
6.0 1955 is offline   Reply With Quote
Old 01-26-2012, 08:35 PM   #13
mooseknuckles
mooseknuckles's Avatar
Re: adapter plates?
trans dapt
mooseknuckles is offline   Reply With Quote
