4x4 swap to a 2wd
I need help workn on blazer with my daughter we decided to do a 2wd swap from a 4x4 71 blazer how hard is it will it require fabrications? what's the easiest way to do this at home without buying a kit...We wanna make it stock NO air bags,4links just stock.Is it possible to keep our brakes/ 6 lug set up front and back? Thanks for the help in advance...
Re: 4x4 swap to a 2wd
I would saaaayy....buy a '73 up 1/2 ton 2wd parts truck, swap the front crossmember into yours and use the 2wd rear springs. If needed you can get 6-lug rotors for the front pretty cheap.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
Thanx Tony I was reading a post/thread you CAN'T use 4x4 steering column? So doin the different years won't require any fab work we have NO welder or plasma cutter we are doing this for the first time don't wanna start what we can't finish at home...Thanks for the help..
Lemme show you something!!
Everything you need to do should be feasible without the need for a welder or plasma cutter. It's all bolt on- however getting the factory rivets out will require a grinder and/or drill.
Remember you will be ditching the entire front differential and leaf springs- so if you want to keep it 6 lug, you'll need to get the front suspension x-member off of a 67-70 2wd truck. You can leave the rear in place, but may want to get some lowered springs, drop shackles and/or flip kit to get the ride height correct. Or you can ditch the leaf springs and grab the trailing arms, differential and rear cross members and convert the rear to coil springs. I've never heard of not being able to use the 4wd column in a 2wd conversion, but then again I don't know everything....i'm sure somebody w/ more experience in this will chime in shortly. Good Luck and post up some pics......it's the rules- man!
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
#5 | |
