#1 | |
![]() Join Date: Dec 2011
Windshield wiper "parking"
The windshield wipers on my 1972 Blazer park successfully when turned off.
But they park at the very top of the travel instead of the bottom. ![]() I did some searching, and I'm hoping it is as easy a fix as it looks to be.... I found this thread, talking about wipers: http://67-72chevytrucks.com/vboard/s...d.php?t=316642 And the second post says: Quote:
Basically move the arm on the motor over to where the blue is drawn in: ![]() Would be nice if it was this easy. Have looked under the dash and it does not look like it would be fun to have to pull the motor. Should this fix it? |
Re: Windshield wiper "parking"
I had this same problem on my 65 Impala. If you have the correct linkage arm on the motor, I think you should be able to just flip it 180 degrees.
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold |
The Older Generation
#4 | |
And they park, just at the top, not at the bottom. If I shut the wipers off when the are at the bottom of the travel, the will go all the way to the top and park. |
If I remember correctly the motor will always park at the same spot, so if the arm can be swung, that should fix it. Should.
![]() Join Date: Sep 2000
Can you pull wipers blades off, turn on wipers button and then shut off wiper button, then re-install wiper blades. Should help.
69 stepside, 1/2ton, 4X4, 350/350/205 |
Won't work, the pivots will still be stopping in the UP position, if you put the arms on in the down position, the arms will try to go down into the hood! Won't be a pretty sight.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Swapping the arm 180 degrees fixed it.
Thanks Posted via Mobile Device |
