Old 01-25-2012, 06:53 PM   #1
sovapid
sovapid's Avatar
Originally had utility buckets?
My Blazer has some non-stock seats in it. I'd like to switch back to stock.
Based on this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=322837
I'm pretty sure it originally came with utility buckets.
It is just over 15" between the front mounting bolts and the rear on the driver's side.
Just want to make sure, as I don't want to go through all the hassle of finding a set, getting them shipped out and then finding out I misread something....
sovapid is offline   Reply With Quote
Old 01-25-2012, 07:05 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Originally had utility buckets?
There are also two types of utilities...the bottom cushion sits flatter on some, i think they came on panels trucks, dunno
Make sure you get a set with the proper tilt
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-25-2012, 07:19 PM   #3
sovapid
sovapid's Avatar
Thanks! Had not run across that in my research. Are all utilities out of Blazers the same?
When you say proper tilt, are you referring to the tilt on the passenger side so you can get into the back seat?
Old 01-25-2012, 11:12 PM   #4
jaros44sr
jaros44sr's Avatar
No, the rake or tilt, im referring to has to do with how you fit in the seat. If the back of the seat were to high, it would feel like you were going to hit the windshield when you hit the brakes hard
Ill have to measure my seat brackets when i get home, maybe that will make it clearer to you
All utility seats out of blazers/jimmys are the same
SAFETY FIRST
AS usual, off topic
Jim
Old 01-25-2012, 11:21 PM   #5
sovapid
sovapid's Avatar
Ok, that makes sense, I get what you are talking about now.
Old 01-25-2012, 11:46 PM   #6
rsavage
rsavage's Avatar
Is your SPID still on the glove box door? That will tell you if you had utility buckets. The passenger utility bucket ( a second front seat was actually an option) will be listed as 1AN3AA Heavy Duty Aux Seat.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-25-2012, 11:51 PM   #7
ls1nova71
ls1nova71's Avatar
Too bad you are not close to me, there has been a set of utility buckets in a u pick it junk yard by me for several weeks. Everytime I go down there I think they are going to be gone but they never are.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-26-2012, 01:01 AM   #8
sovapid
sovapid's Avatar
Yeah, it's long gone.....
Old 01-26-2012, 06:53 AM   #9
rsavage
rsavage's Avatar
I did some measuring on my utility bucket seat brackets. The driver's side front brackets outer bolt holes are 17 3/4" apart center to center and the inside bolt holes are 10 3/8" center to center. If you measure back from the center outer front bolt hole on the outside of the driver's seat to the center of the outer rear bolt hole you should have 15 3/8 ". The rear outer bracket holes measure 16 1/2" center to center and the inner holes measure 12" center to center.
The passenger bucket flips forward for rear seat entry. The front brackets which are hinged measure 15 3/" center to center for the outer holes and the inner holes measure 11 1/4" center to center. The rear has a bracket held by two bolts. A trunion on the rear of the passenger seat bottom locks into this bracket. I have a couple of photos of the bolts in the floor for reference. You can see the passenger rear floor bracket.
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-27-2012, 05:19 AM   #10
fleetwoodss
@ls1nova71
can you get me the brackets out off that wrecker? thanks
fleetwoodss is offline   Reply With Quote
