Old 01-25-2012, 10:14 PM   #1
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
Under Bed Ramps and Holder
Anybody have pics or a link to an under bed ramp/holder system? I'm looking to build my own for my '79 and would like to see what others have done, if anybody. I've dealt with carrying ramps in the bed and i would rather use the space they take for other things. Ramps would be used primarily for carrying dirtbikes, a quad, and DR brush mowers, along with any other wheeled/heavy item i need to load.
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 01-26-2012, 08:17 AM   #2
Goldfinger
Goldfinger's Avatar
Re: Under Bed Ramps and Holder
depending on the ramps all you would need to do it to design a slide out where the spare tire goes. http://www.mappcaster.com/images/Magline/Ramp-sli.jpg. those are what i usually see on the semi's i unload. they go over the rear axles and some have pins or notches to keep them from moving when unwanted.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 01-26-2012, 12:03 PM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
this where/how the ramp's on my car hauler store, you could do some then simular to you rear bumber. if ya can cut it straight enough you could even reuse the cut out peice for the door.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-26-2012, 12:23 PM   #4
stroker87
you would need a long ramp to go up to the bed?
are you looking to make it slide in the bed or under it?
if you was going under would there be enough room to clear the axle when loaded?
its a cool idea maybe built a raised floor or a box in the bed high enough to slide ramps in?
stroker87 is offline   Reply With Quote
