Old 01-25-2012, 11:59 PM   #1
mjo8585
mjo8585's Avatar
1974 GMC 3/4 ton lowering questions,
Hello I was wondering if a 3/4 ton 2wd truck can be lowered. I was looking at buying one this weekend but wanted to know this before I purchase it. Thanks everyone for the help I really appreciate it.
mjo8585 is offline   Reply With Quote
Old 01-26-2012, 12:05 AM   #2
ghettoluxury
ghettoluxury's Avatar
Re: 1974 GMC 3/4 ton lowering questions,
Yes the can. All the suspension components are close to the same as 1/2 ton. The lower control arms have larger ball joints but even the aftermarket support them.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-26-2012, 12:10 AM   #3
80SPORT
80SPORT's Avatar
While you can lower a 3/4 ton with spindles and hanger kit you may want to consider switching to a 1/2 ton suspension ...much better selection of wheels.
Just swap out your rear axle and springs....lower control arms and springs and upper ball joints for 1/2 ton parts...use regular 1/2 ton drop spindles
80SPORT is offline   Reply With Quote
Old 01-26-2012, 12:27 AM   #4
ghettoluxury
There is no need for that since the aftermarket support for 8 lug 4x4's is so great. You can get rims into the 24" range with the correct backspacing very easily. I have a set of 8 lug 20's in my garage with 5" of back spacing, perfect for a lowered 3/4 ton truck. These rims can usually be bought cheap used because guys don't want to shell out the cash to replace there off road tire once they are bald.
Old 01-26-2012, 12:43 AM   #5
tc4x4
tc4x4's Avatar
Its totally possible and these guys on here will help a ton along the way. Here is a link to a thread I started asking a TON of questions with answers about lowering 1 tons and 3/4 tons. Keep it a 3/4 ton, not as many lowered ones out there like the half tons, its just another way to be unique.
Link to lowering a 1 ton and 3/4 ton thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=502593
A lot better info as you go, and different dropping ideas...
Link to my build.
http://67-72chevytrucks.com/vboard/s...d.php?t=503961
tc4x4 is offline   Reply With Quote
Old 01-28-2012, 10:50 AM   #6
pig rig
pig rig's Avatar
lowering a 3/4t takes the same parts as the 1t
thats your cheepest and easiest way to lower a 3/4 ton
Ive done it dont swap to a 1/2t if you use a 1t spendel all you need to swap is calipers to 1ton
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 06-02-2012, 10:15 PM   #7
79 blue monster
79 blue monster's Avatar
did you ever buy it? i have a 3/4 ton that i bought not sure of lowering, and i asked questions, and here i am today with it lowered in my driveway. best decision i ever made! its more unique then the 1/2 ton!
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP
http://67-72chevytrucks.com/vboard/s...d.php?t=518625
1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972
79 blue monster is offline   Reply With Quote
