1960 mirror holes
Hi Iwas trying to find a measurement where the original mirror holes been. the previous owner had filled them in. I would like to put stock mirrors on the doors. thanks
Re: 1960 mirror holes
If you take off the inner door panel, you should be able to reach inside and feel the support plate for the mirrors. I used a spring punch once I located the plate and then drilled from the outside. You will find a support brace on the passenger side also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
they put the bolt in the holes. that why I need a good loction on holes to drill and tap
See if this helps. This is from the passenger side. Driver side was in sun and pics were bad.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 01-26-2012 at 02:57 PM. |
Senior Enthusiast
Welcome to the forum. Posts #7 & 14 on the following thread should help you out. Also note 1960-63 mirror brackets are generally parallel to the body line. 64-66 are usually at an uphill angle as shown in the following photos:
http://67-72chevytrucks.com/vboard/s...irror+template ![]() ![]() |
![]() Join Date: Jul 2009
The mirror mounting holes in my drivers side door were plugged also. I sanded the surface down to bare metal which exposed the circular break lines of the three plugs. I drilled the plugs out and chased the threads in the captive nuts. I then made a template from some thin cardboard and used the reverse image on the passenger side door to locate where to drill the holes.
Cool, glad you were able to complete it. I was going to suggest buying the gasket or tracing the bottom of the mirror for a template.
On another project car I had, I had the same problem! What I did was take a large piece of paper and trace the pattern of the mounting flange on the mirror (outline only) ...then I cut that out. I then went to another car like mine, positioned the paper so the cut-out outline was around the mirror on the car. Then with a pencil I marked on the paper the edges of the door. Obviously the paper was large enough to do at least 50% of the door. I then put the paper back on my car, taping it in place, then put the mirror in the cut-out hole ...again with the pencil, I marked where the holes would be. Worked like a charm for me, I think I was right on in one hole and maybe 1/16" off in the others. ...Good Luck!
