Old 01-26-2012, 02:29 AM   #1
RRR18
RRR18's Avatar
Question Give me some help
Ok guys I fought with myself and others over and over so now it can be your turn. I'm in need of some help AND opinions. Don't hold back...really.
This is my '67. I pretty much bought it like you see apperance wise. Entire powertrain was redone by me. Everything else body and chassis was done by previous owner. It's static dropped....low.....5"front 7"rear maybe.?. It's low. Tire sizes 235 60 15 front and 275 60 15 rear. Disc brakes in front. 5 lug all around. Has a cnotch. Everything seems to be done correctly. So....should, if, or when I decide to change anything...could I? I have searched many builds on here and love the work you guys put into your trucks. I just am limited with the experience I have on wheels with backspacing and static drops and air ride. One thing I do know is that I will not cut the truck any more than the cnotch that it already has.
-Can I fit 20"s on it....if so tire size?
-Do I have to bag it to do anything else other than what it is?
I can barely get a beer can underneath the front bumper so ya it's kind of a ***** to drive, but the stance is killer to me so I put up with it. Let me know what you all think. I tried to let ya know all I can think of but I'm sure I left some info out. Thanks
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 01-26-2012, 03:16 AM   #2
79shortbed
79shortbed's Avatar
Re: Give me some help
I think some 17 or 18 inch torq thrust IIs or similar wheel would look awesome and still have some sidewall to ride decent. I agree, the stance looks amazing!
1979 Custom Deluxe C10 SWB Fleetside
Help encourage me in my build.
LS 5.3 swap in progress!
79shortbed is offline   Reply With Quote
Old 01-26-2012, 09:27 AM   #3
SCOTI
SCOTI's Avatar
235-60-15 = 26" tall tires. The closest thing in a 20" would be 245-35-20's @ 26.75". Things to consider:
Wheel width... the 245's on a 20 would likely be an 8" wide wheel & with that drop prob require about 5.25" back spacing. This needs to be considered (is there enough room in the wheel well @ your current drop??).
Tire section height... that's the height of the tires sidewall. The 245-35 series tire is short (<3.5" tall) so it will detract from the current ride quality (if it's bad now, it will only get worse). Pot holes start to become a concern for many wheels as damage could occur.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-26-2012, 11:47 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
It looks b!tchen right now. If you feel the need to change it, I would consider bags. Cruise low and ride high so you can bolt on those 20's you really want.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-26-2012, 11:57 AM   #5
tubbedII
needs more $$$
tubbedII's Avatar
X2!!! I don't see a need to change it. You said it's a pain to drive, but swapping to bags may not be the best thing if you still want to continue to ride that low...that'd be a low pressure and not the best ride. My only concern with that ride height is how low the front crossmember/lower control arms are to the ground...do you scrap them a lot?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-26-2012, 12:08 PM   #6
RRR18
RRR18's Avatar
79shortbed......thanks for your input. I've thought about this setup aswell.
'67 BAD IDEA
Ryan
Old 01-26-2012, 12:15 PM   #7
RRR18
RRR18's Avatar
SCOTI........as always thanks for your pro approach to my questions. Some good points to think about. I've wondered if 20"s would even fit and best I can see is if they do it would have to be on a 35 series tire. Not sure I'd like to do that. I'm not saying that the guys that run them on this site have a bad setup I just don't think I can do that in NE Ohio. Our roads aren't the best around here. Far as I can see in the garage tonight I got "some" room but it ain't a whole lot. That's why I decided to let you guys throw stuff at me.
'67 BAD IDEA
Ryan
Old 01-26-2012, 12:17 PM   #8
RRR18
RRR18's Avatar
N2TRUX......Thanks. Ya it's easy to say to go to bags...another to figure out what'll fit properly and look the best at the same time. That's where my problem lies if I intend on changing anything.
'67 BAD IDEA
Ryan
Old 01-26-2012, 12:26 PM   #9
RRR18
RRR18's Avatar
tubbedII......thanks for the reply. Your 100% correct with your concern on my current front ride height. I don't have a measurement at the moment but the arms are low. Ya, I bump and grind here and there. Maybe 3 to 4 times in the almost 2 years I've owned it. I've learned to plan my driving route before I go anywhere and my eyes are peeled to any "road hazard". Just something I've learned to deal with.
'67 BAD IDEA
Ryan
Old 01-26-2012, 12:31 PM   #10
RRR18
RRR18's Avatar
Keep it coming. Remember this....I live in NE Ohio and my truck gets to sit for 5 months a year so stuff starts building in my head. Pity me. HA!
'67 BAD IDEA
Ryan
Old 01-26-2012, 12:31 PM   #11
big_al_71
big_al_71's Avatar
yes but each truck you have to measure to make sure..
I would bag it as it makes life alot easier since you can adjust height
You can achive even a lower stance with bags and when driving it will ride 100% better than it does now.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-26-2012, 12:32 PM   #12
SCOTI
SCOTI's Avatar
IMO, consider the 245-40-20 @ 27.71 & run some taller inner fender wells....
http://67-72chevytrucks.com/vboard/s...d.php?t=486039
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2012, 12:44 PM   #13
RRR18
RRR18's Avatar
Ah ha...big al....I knew you'd be chiming in. If there ever was a truck to model after in my opinion it would be yours. Your build is well thought out and just matches up perfectly.
'67 BAD IDEA
Ryan
Old 01-26-2012, 12:47 PM   #14
RRR18
RRR18's Avatar
Ya that crossed my mind too about the 40 series. As far as the link about the fender wells...that just seems like a little more than I wanna do to my bed though.
'67 BAD IDEA
Ryan
Old 01-26-2012, 01:05 PM   #15
RRR18
RRR18's Avatar
Something else I guess I should have considered was a staggered wheel combo also. Example: 18s and 20s
'67 BAD IDEA
Ryan
Old 01-26-2012, 02:59 PM   #16
SCOTI
SCOTI's Avatar
You would have more clearance in the rear & wouldn't need changes unless going extremely low, adding a much wider wheel/tire combo, or both.
The front inner wells will get buzzed by the tops of the tires unless they're removed or raised (when super low). Your current drop amount is prob right on the bubble & my guess is they would rub w/the 245/40-20 combo in front.
For the rears, a 295-40-20 on 9.5-10" wheels would match well (like 'big-als-71).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2012, 03:28 PM   #17
big_al_71
big_al_71's Avatar
Thanks Ryan!!!!!!!
I truly appreciate it!!!!
Old 01-26-2012, 04:46 PM   #18
RRR18
RRR18's Avatar
I agree with your front estimate. I also think it would be tight fi for 245/40-20s. I just think they're too tall.
'67 BAD IDEA
Ryan
Old 01-26-2012, 07:04 PM   #19
hatechew
20" in the front pretty much gives you two options. Raise it or bag it. You don't want 35 series sidewalls where you live. Staggered 17 & 18 or 18 & 20 look killer on these trucks and would probably work with your suspension as is. Just have to get your b.s. right and you can have some sidewall.
hatechew is offline   Reply With Quote
Old 01-26-2012, 07:52 PM   #20
SCOTI
SCOTI's Avatar
No inner fender mods here & it's running 255-40-20's....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2012, 08:02 PM   #21
RRR18
RRR18's Avatar
SCOTI.....I assume that's on bags.?!
'67 BAD IDEA
Ryan
Old 01-27-2012, 01:58 AM   #22
SCOTI
SCOTI's Avatar
Yes it was. When air'd up to ride height, it was about where your truck appears to sit but it would buzz the tops of the wells on moderate road stuff from what I remember. Of course w/bags, it could go higher as well....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-27-2012, 09:53 AM   #23
gringoloco
A guy with a truck
gringoloco's Avatar
~5.5-6" static drop up front. 255/40-20 on 8.5 wheel w/ 5.25 backspacing. Rubs only on big dips...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-27-2012, 01:48 PM   #24
RRR18
RRR18's Avatar
Thanks for the pic gringoloco. It just looks like mine is lower and that won't work.?.?
I'd like to get a 295/40-20 on a 10" wide wheel underneath the rear. I'm sure with the proper backspacing that won't be a problem since my ralleys backspacing pushs the tire way out to the bedside lip leaving much room there behind in empty wheel tub land.
The front continues to be a major jerk off. I know it would be easy if I knew the exact drop or had put this stuff on myself. I'd love to get a 20" in there, but if it don't fit it don't fit. If I have no other option then 18" it is. Is there any way to measure for clearance or should I find a real nice local tire shop guy that might by the grace of god let me test fit different things?<----Ya right!!! I would really hate to buy two sets of front tires and wheels if I don't have to.
'67 BAD IDEA
Ryan
Old 01-27-2012, 02:00 PM   #25
gringoloco
A guy with a truck
gringoloco's Avatar
It will end up higher due to the overall tire diameter. You could always swap in a known quantity drop spring...
-Chris
