Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-26-2012, 04:21 AM   #1
Handfull 54
Handfull 54's Avatar
Tire Pressure
I have Mickey Thompson Sportsman 31x18:50x15 tires on the rear of my truck. I don't seem to get the full pattern of rubber on the street. Mostly it looks like 4 lines. I am using about 12 lbs of pressure. I have a 4 link setup with coil over shocks . I know you guys have the answer as to how much pressure to use. Thanks.
Handfull 54 is offline   Reply With Quote
Old 01-26-2012, 09:34 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Tire Pressure
12 psi is in the ballpark for the street tire. The four lines you are seeing are the tread pattern, which is about the correct contact patch width when the tire grows and the tread crowns.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-26-2012, 10:58 AM   #3
bigboybodry
bigboybodry's Avatar
Re: Tire Pressure
I have had several sets of these tire and they never wear ever. Thought it was something I was doing but started looking at other people that were running a sportsman and they too were having the same problem. Do you have a pic of the wear pattern, mine always wear on the inside edge.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 01-26-2012, 01:36 PM   #4
Handfull 54
Re: Tire Pressure
Thanks for the info. What I ment by four lines is that it looks like this // // with nothing in the middle making me believe that I was under inflated.
Old 01-26-2012, 02:12 PM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Tire Pressure
Sportsman's or Sportsman Pro's? The regular treaded "MT sportsman" are hard as nails. You better have a ton of $#!+ in the back to get them to hook. I tried them long ago with a 4link double adjustable coilovers and never could get a 60 under 1.9, Changed to a Hoosier QTpro and went to high 1.5's without changing a thing. For the sportsman,, like said they don't wear because there so frickin hard.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
