Old 01-26-2012, 12:10 PM   #1
Gregsenne
1986 brake splitter wire?
Inside a crossmember behind my radiator is what looks like a brake line splitter. there are the two lines that go up to the master cylinder and then a line out for rear brakes and two out for each of the front brakes. It also has a tan wire coming off of it. What is the wire for? What do I hook it up to?
I'm doing a complete rebuild, and trashed my wiring harness and made my own, so I need to know what to do with this wire!
Thanks.
Gregsenne is offline   Reply With Quote
Old 01-26-2012, 02:38 PM   #2
Gregsenne
Re: 1986 brake splitter wire?
Think I answered my own question. That splitter thing is a porportioning valve, and that wire will read ground should there be a brake issue, such as air in the line or low pressure. The grounded wire would turn on the brake light on the dash, the same light the parking light is.
Am i right?
Old 01-26-2012, 02:57 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
U got it. although the reference to the parking light is confusing me.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 01-26-2012, 03:58 PM   #4
Gregsenne
sorry meant parking brake light. thanks for confirming my idea.
Old 01-26-2012, 06:46 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
ebrake ?is run off the top of the assembly by the fuse box
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
