Old 01-26-2012, 01:20 PM   #1
Pro Performance
Pro Performance's Avatar
Changing to Power Windows
My truck originally had manual windows, and I bought a set of doors that have full power. I removed the plate in the door jamb where the wire pass through, but after that I can seem to get them inside the cab. There is a double walled panel.
Has anybody done this or can help me figure how to get the wiring through the double wall panel?
Pro Performance is offline   Reply With Quote
Old 01-26-2012, 03:08 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Changing to Power Windows
You will have to drill a hole on the inside kick panel, and keep drilling until you reach the inner structure, drill thru it too. Route your wires, when you finish, simply plug the hole with a cap/grommet, and bolt your kick panels back up. I did this on my 73
bigblock73 is offline   Reply With Quote
Old 01-26-2012, 05:18 PM   #3
Pro Performance
Thanks for the info. I guess having a hole there isn't too bad, because it will be covered by the kick panel. I thought maybe there was a way to do this without having a hole.
Old 01-26-2012, 05:33 PM   #4
joe231
joe231's Avatar
What year truck.
On my 81-91 crew cab there were holes above the bottom of the dash.
I had to drill the outer (there were locating indent ions indicating where to drill), but not the inner.
The 77-up should have the proper hole, that's when power windows became an option (IIRC)
I might have pics.
CHEVY ONLY
Old 01-26-2012, 05:47 PM   #5
Pro Performance
I saw where the hold is in the door jamb, but after that, it goes into a double wall panel that I am unable to get to. I will double check though. I think the hole your talking about, may not be large enough to reach in.
I cut my dash out, so I will double check and might have easy access.
Old 01-26-2012, 05:55 PM   #6
joe231
joe231's Avatar
Yeah, it is tight but do-able.
You have to snake it up there.
CHEVY ONLY
Old 01-26-2012, 05:56 PM   #7
Zebb
Zebb's Avatar
This is what I did on an 87 cab that had the dimples already there for reference.
This is the factory boot that I got with the rest of my power window and lock stuff.
Zebb is offline   Reply With Quote
Old 01-26-2012, 06:28 PM   #8
Pro Performance
That's how mine looks now. Thanks for the pictures, I will fish through the double wall panel on the inside of the cab. If not, drill a hole like bigblock73 mentioned.
Old 01-27-2012, 11:06 AM   #9
bigblock73
yeller
bigblock73's Avatar
I am pretty sure the early cabs will not allow you to fish the wires thru there...I tried. GM may have changed the inner cab structure when power door options were offered, to allow the wiring to snake thru back to the fuse block.
Old 01-27-2012, 11:11 AM   #10
Migbou
Im looking to do the samething on mine, any wiring diagrams for reference?
Migbou is offline   Reply With Quote
