Old 01-26-2012, 08:26 PM   #1
Fangio
Fangio's Avatar
Installed CPP suspension and now the truck sits lower on the passenger side
Like the title states, installed CPP springs and shocks on my 64 c10, 4 inch drop rear 3 inch in the front. After putting the truck back on the ground the passenger side is sitting about 2 inches lower than the drivers side. The difference from side to side is a little bigger in the rear than the front, but it is still pretty consistent. Any ideas on what to check?
Fangio is offline   Reply With Quote
Old 01-26-2012, 09:13 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Installed CPP suspension and now the truck sits lower on the passenger side
Are the springs sitting in the spring pockets correctly? That can definitely make a difference. 3" drop springs are so short, I had problems that when I jacked the truck up and the suspension would drop, the springs would unseat themselves and sometimes I would have to manually rotate the springs to get them back in the seats correctly.
Going to 2" drop spindles and 1" drop springs cured that problem and rode some much better.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-26-2012, 09:32 PM   #3
losthope
losthope's Avatar
I would check what chevy_mike said...but if you still have the problem id check and make sure you didnt get a bad shock ,or wrong shock..could unhook the shocks and see if it levels out the truck or not.
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
