Old 01-26-2012, 09:33 PM   #1
Hduramax
Hduramax's Avatar
"cruznby" w/ big block
I have had this truck up before but all my pics got wiped out, so since I had not got going on the truck I thought I would start over. Here is what I am starting with:Its a 1969 swb, I got it with no motor, no tranny, which was fine cause I bought a 8.1 from an 05 3/4ton, got the tranny and the computer's and plan to use some of the brake system.
Mods in the future:
drop 5/7
shaving everything (debating door handles may swap newer style flush one's)
c-notch
wood bed (rustic Hickory)
fuel cell or tank from a 4th gen camaro
Going to do something to hood(like a 2010 camaro scoop)
drop in BB and 4L80
newer gauges
custom center console
18x9F/18x12R (plan to use the rear wider wheelwell's)
I am sure i missed something but it will be noted when i get to it
Got the bed and front clip off
Had to pull front clip cause i found this,It was hid by bondo
Anyway thats where I am got the interior pulled also will post some more pics on that later after I load them
2008 HD
2010 Camaro 2ss (The Wife's Ride)
2005 Suzuki GSX-R 1300 "Busa"
1969 C-10 (under Construction)
2013 Sonic LT
"LIVE LIFE,TASTE DEATH"
Hduramax is offline   Reply With Quote
Old 02-05-2012, 11:45 AM   #2
Hduramax
Hduramax's Avatar
Re: "cruznby" w/ big block
Pic of the motor
2008 HD
2013 Sonic LT
Old 04-25-2012, 08:11 PM   #3
Hduramax
Hduramax's Avatar
well I have been picking away at the rotted cab on and off for a while now got to this point
and thought there has to be an easier way to fix this mess and then i found this beauty on CL in Michigan of all places 30 min from my house, it is a rust hole free, no rot cab, that other then a couple changes to suit my needs is ready go, I need to find a media blaster in the area to take care of some surface rust and the rest of the paint, but other then that
I also got the motor and tranny seperated,so i can get a new tailshaft installed(its out of a 4x4) and started pulling harness off the motor to send out and get de-turded.Progress is being made slowly but surely.
2008 HD
2013 Sonic LT
Old 04-25-2012, 09:41 PM   #4
Tinkermc
After looking at the rust bucket of a cab that U had I think the new cab is a wonderful idea and sure to save some time
Tinkermc is offline   Reply With Quote
Old 10-04-2012, 08:36 PM   #5
Hduramax
Hduramax's Avatar
well its been a while since i had a chance to work on the truck, but we got motor sitting in the frame, headers fit and tranny mount is set. Pulling the rusted out mock up cab soon, and will be mounting up the new one.More pics soon to come
2008 HD
2013 Sonic LT
Old 10-04-2012, 09:41 PM   #6
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Sweet build.
--Josh
Old 10-05-2012, 02:51 AM   #7
nuke1
nuke1's Avatar
WOW that cab was bad!! glad you found another one. Should be a nice toy once up and running with that engine.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-05-2012, 10:30 AM   #8
67cheby
67cheby
67cheby's Avatar
looking great ready to see that pretty new cab progress !
67cheby is offline   Reply With Quote
Old 10-05-2012, 06:29 PM   #9
67c10rustbuket
67c10rustbuket's Avatar
Great looking project! Man that original cab is bad rusty, glad you found such a nice replacement.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-09-2012, 01:30 PM   #10
ksucatz
Suppose to be workin........
ksucatz's Avatar
What headers are you using? Do you like the fit?
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
"Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown
ksucatz is offline   Reply With Quote
Old 10-25-2012, 08:40 PM   #11
Hduramax
Hduramax's Avatar
drivers side header needed a little more room, PO took care of that for me engine stand is notched around the first tube, I will beef it up when I box in the frame in that area
2008 HD
2013 Sonic LT
Old 10-25-2012, 08:48 PM   #12
Hduramax
Hduramax's Avatar
Got cab and doors back from sandblaster, they look great no unseen damage in the cab or doors, the guy that did the sandblasting said that everything was really solid. Had everything covered in a epoxy coating to prevent rust. Hope to get old rusty cab off this weekend, And start boxing in the frame, and installling the C-Notch
2008 HD
2013 Sonic LT
Old 10-25-2012, 08:51 PM   #13
Hduramax
Hduramax's Avatar
Pic of poly mounts
2008 HD
2013 Sonic LT
Old 10-25-2012, 09:49 PM   #14
gdavis
gdavis's Avatar
Mods in the future:
drop 5/7
c-notch
drop in BB and 4L80
newer gauges
That bondo hides a lot of sins. That is sad.
gdavis is offline   Reply With Quote
Old 12-05-2012, 10:21 PM   #15
Hduramax
Hduramax's Avatar
got a little done in the past couple weekends,made a cradel to pull my old cab, didnt quite take the weight difference into account almost dropped it,(not like its going back on lol)
got the motor and tranny back out also, got the tranny crossmember set where it needs to be, and started making the mess on the floor with various wire wheels. Found out my buddy can clean all my front suspension parts at work with a sonic parts cleaner,SWEET
getting ready to fix up frame now, more pics to come
2008 HD
2013 Sonic LT
Old 01-12-2013, 08:44 PM   #16
Hduramax
Hduramax's Avatar
got a little more done on truck pulled all the front suspension to get it ready for drop and paint
and i got frame fixed where PO cut it to fit his headers, the white paint is just primer to prevent rust
still have to do a little grtinding to get it nice like the drivers side
2008 HD
2013 Sonic LT
Old 01-12-2013, 09:35 PM   #17
67cheby
67cheby
67cheby's Avatar
Nice work
Old 01-12-2013, 10:17 PM   #18
67ctener
67ctener's Avatar
Some serious wheel tubs in the back, looks like you'll be running some serious rubber
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 01-13-2013, 01:02 AM   #19
Hduramax
Hduramax's Avatar
Thanks 67cheby coming from you after seeing your sweet ride that boosts the spirits
2008 HD
2013 Sonic LT
Old 01-13-2013, 01:07 AM   #20
Hduramax
Hduramax's Avatar
67ctener I do plan on runner some large tires i am planning on some 20x11 if the budget allows we will see thanks for looking
2008 HD
2013 Sonic LT
Old 07-07-2013, 09:54 AM   #21
STOCKISH
STOCKISH's Avatar
Looks like its coming right along. That cab looks killer! Look forward to more progress.
--Josh
Old 07-07-2013, 04:37 PM   #22
Hduramax
Hduramax's Avatar
been a while since I have posted but got the front suspension back in for a test fit
I currently have the rear end tore apart to put in c-notch, 6" drop springs, 1" lowering blocks. I am also building my own rear disc brake set up, promise to post pics as soon as I can find them
2008 HD
2013 Sonic LT
Old 11-15-2013, 11:12 PM   #23
Hduramax
Hduramax's Avatar
Got my rear disc brake set up done,made my own rear caliper brackets,used 05 avalanche rear calipers and 00' chevy truck front rotors. C-notch is in and I debated on flipping the trailing arm brackets for my drop and decided it was a way better idea to order PB's trailing arm cross member. Way more options for adjustability with that option. Couple more weeks I will be able to disassemble and paint frame and components. Next up fuel system for the 8 liter.
2008 HD
2013 Sonic LT
Old 11-15-2013, 11:14 PM   #24
Hduramax
Hduramax's Avatar
Well pics won't post I will try again tomorrow
2008 HD
2013 Sonic LT
Old 11-28-2013, 04:40 PM   #25
Hduramax
Hduramax's Avatar
got pics to work, first one c-notch, second one my rear brake set up
2008 HD
2013 Sonic LT
