700r4 part throttle shift points
At what general speed and rpm do your 700r4s make their shifts? Say, leaving a stop sign or light just keeping up with traffic not flooring it or anything. I ask this because sometimes I feel mine shifts a bit too early, but only during part throttle, not wot. It usually shifts from 1-2 around 8-10 mph at around 1800 rpms or so. And before you ask yes the tv cable is correctly adjusted. This is in an 85 k10 with 4.11's and 33's. Thanks
Re: 700r4 part throttle shift points
anybody?
One shot, one kill.
DR. the 700 has a low 1-2 shift to start with at light throttle, now add a 4:10 rear and it gets lower yet. It's fine, jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
1-2 [7 mph] 2-3 [50] 3-4 [70]
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
Since you asked when the shift points should be I now have to ask. I believe my trans is about shot.. but anyhow... My truck doesnt shift from 1st to 2nd till 25MPH!!! This si under regular driving or flooring it... uhhhh.... So lets just say my 350 is getting like 5 miles to the gallon... because it does it all the way through the gears. Wont hit 4th till just over 55mph...
Any ideas??? |
#6 | |
If so the TV cable is out of adjustment Posted via Mobile Device
My truck is an all stock 85 K10. When I had the tranny rebuilt the tranny guy told me it should shift 1-2 between 18-20 MPH. This is under normal acceleration. By the way it is a 700R.
Shift points on the 700R4 can vary greatly from vehicle to vehicle. It depends on gear ratio, throttle position, weight of the vehicle, and Throttle valve (in the valve body) position.
The TV cable varies line pressure based on throttle position. Late shifts are due to higher line pressure. Shifting too early is low line pressure. Driving with a mis-adjusted TV cable with too low line pressure can smoke the clutches in a matter of a few miles. On the other side, late shifting most likely will not cause damage to the trans but is a pain in stop and go driving. Just thought I'd throw that info out in case anyone wasn't aware. Adjusting the TV cable correctly is a pretty easy procedure. Posted via Mobile Device
#9 | |
BAD BOW-Silverado XST
1st - 2nd -15 MPH
2nd - 3rd 25-30 MPH 3rd - 4th (OD) 45 MPH These are approximate factory shift points. WOT shifts are controlled by the governor. |
#11 | |
I have a governor calibration kit and by adj I can change all the other shift points,but not the 6 mph 1st to 2nd...I was very concerned a bout the 6 mph shift into 2nd. any thoughts??? thanks |
