Old 01-26-2012, 10:46 PM   #1
TX58
Anyone replace inside cab steps?
I purchased both sides because mine were rusted thru in a couple places. Any tips on doing these right? How much of the existing step should I cut out? What's the best way to peel back the overlap floor metal that folds down over the top vertical part? The replacements include rocker
TX58 is offline   Reply With Quote
Old 01-26-2012, 11:40 PM   #2
jimig1
jimig1's Avatar
Re: Anyone replace inside cab steps?
They are pretty easy to do. here is a step by step http://www.brotherstrucks.com/techar...20AND%20ROCKER
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 01-27-2012, 12:50 PM   #3
TX58
Thanks, looks easy but I know it's a little more involved.
Old 01-27-2012, 01:26 PM   #4
_Ogre
_Ogre's Avatar
no actually it's pretty much like that, what they don't mention is how poorly any aftermarket panel fits.
the only thing different i did is to weld a piece of angle in the door frame to hold the jambs together.
once you start it's not that hard, of coarse once you start you find more rust, but that's another story...
the rocker will not match your cab or fender until you get a couple of guys to bend up/down to match.
shop air compressor timer
Old 01-27-2012, 01:27 PM   #5
jimig1
jimig1's Avatar
They are not really that hard I just drilled out the spot weld and use a cut off wheel to cut it about and inch from the edges and just worked the old one out. The new one fit almost perfect then spot welded it back in.
MSRA Member
-George Carlin
Old 01-27-2012, 10:11 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
You should read this series of articles at webrodder.com
http://www.webrodder.com/article.php...95&SID=60&CID=
dwcsr is offline   Reply With Quote
