tcoop68
Mount question
Can you put a BB in place of a SB , 1968 chevy pick up . Are the mounts that bolt to the frame the same.
Posted via Mobile Device |
Re: Mount question
I believe the frame mounts are different, but i'm sure others will have more details. Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed ![]() ![]() 1966 C-10 lwb,factory A/C,Custom Cab ![]() 1954 Delray 2-door sedan [rat rod project]
![]() Join Date: Jan 2012
Re: Mount question
At least for a '72 Suburban, going from a BB to a SB required new motor mounts. I'm assuming it'd be the same situation for a 68, but not positive.
Fabricate till you "puke"
Re: Mount question
You need the BB eng stands/mounts so that the manifolds/headers will clear. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
tcoop68
Re: Mount question
Thanks for the help guys.
