Old 01-27-2012, 12:54 AM   #1
zicc1835
zicc1835's Avatar
WTBUY 4 barrel carb
I have a 1964 327 -300 horse 4 brl intake that I would like to put a Rochester 4jet or a Carter that fits on it ..so anyone who is familiar with this application and has one that will fit, in working condition FS please LMK
thanks
zicc1835 is offline   Reply With Quote
Old 01-27-2012, 01:11 AM   #2
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
Re: WTBUY 4 barrel carb
I have like 15 4-jets sitting in my garage... I will check the dimensions and square bore and get back with you.. They all vary in condition... let you know
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 01-27-2012, 01:21 AM   #3
zicc1835
zicc1835's Avatar
thanks much appreciated
Jess
Old 01-27-2012, 01:26 AM   #4
HeavyMetalChevy
Just a Member
Jess
What is that setting is that micrometer on??? Also what is the dimension of bolt hole center to bolt hole.. I am sure they will work just making it easier on the both of us...
TH400(3rd)
Old 01-27-2012, 10:45 AM   #5
zicc1835
zicc1835's Avatar
Heavy
its set to inches so much for modern tech here is what i have with a good old fashion ruler center to center front to back 5 5/8 side to side 4 1/4 that rear bore is about 1 3/4 with a ruler if you need pics i got them
thanks for your help
Jess
Old 01-27-2012, 10:53 AM   #6
425HP409
425hp409
425HP409's Avatar
The correct carburetor is a Carter AFB. You must also use a stainless steel plate under the carburetor and above the gasket for the exhaust gasses to get to the carburetor to warm it up, but not cause damage to the base of the carburetor. You can also use one of the Edelbrock Performer Carburetors, but I am not real fond of them. What is your application for the intake? I might be able to help you.
Charles
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 01-27-2012, 11:44 AM   #7
zicc1835
zicc1835's Avatar
i put the intake on a stock 283 just want to get it started see how she runs use it to move the truck around the yard while i am building another motor for it so i don't want to spend a kazillion thanks for the help
Jess
Charles
Old 01-27-2012, 02:12 PM   #8
425HP409
425hp409
425HP409's Avatar
If you just want to get it running, you could use a Quadrajet, a Holley, or a Rochester WCFB (that old square type 4 barrel) with an adapter/spacer plate to run it. The Quadrajet and Rochester have the same bolt pattern as an AFB. You just have to make sure that those exhaust ports in the intake are blocked off, or you will have a massive exhaust leak into the intake, which will not it run. For your purpose, you could just use a gasket to block them off. If you want to sell that intake later, let me know.
Charles
90 ZR1 Corvette
Old 01-27-2012, 06:56 PM   #9
zicc1835
zicc1835's Avatar
i have a 327 date coded 1965 with the camel back heads is where that mainfold will finally come to rest unless we go in different directions thanks for your help maybe Heavy metal can come up with one of those 4jets for a couple of shekels if i let that corvette intake go ill keep you in mind thanks for the good info appreciate it
Old 01-28-2012, 08:53 AM   #10
Pro Metal Shop
Hi Zic I will check the carb I have it's fairly new and ran the motor it came in on. I will be up the shop today and post back later.
Thanks Steve
http://chevylegends.com/forum/index.php
Pro Metal Shop is offline   Reply With Quote
Old 01-28-2012, 06:00 PM   #11
Pro Metal Shop
Ok the one I have is off a big block and is most likely not going to work.
Thanks Steve
Old 01-28-2012, 07:40 PM   #12
zicc1835
zicc1835's Avatar
Steve
no that one wont work thanks for trying
jess
Old 01-28-2012, 08:21 PM   #13
Pro Metal Shop
You bet Jess
Thanks Steve
Old 01-28-2012, 08:40 PM   #14
HeavyMetalChevy
Just a Member
Hey Jess, I have tracked down 7 so far... Two Holley's and 5 Q-jets. The 5 jets I have found look the same size diameter as the primary and secondaries on Steve's he pictured. I have plenty more just got to track the box down... PLEASE DON'T LAUGH!!! hah my garage is similar in scope to an indoor junkyard at the moment!!!
TH400(3rd)
Old 01-28-2012, 09:28 PM   #15
zicc1835
zicc1835's Avatar
Duane
i m in the same spot running out a room know i got it just don't no where i left it.......thanks ill wait to see what you come up with.... no hurry on my end ....thanks for looking
Jess
