Old 01-27-2012, 01:19 AM   #1
ralf
What was the stock carb on a 66 C10 250cid?
I would like to run dual single barrels on the stock 250 with long headers. Any suggestions on what intake manifold and which carbs to run, linkage and so on?
ralf is offline   Reply With Quote
Old 01-27-2012, 10:56 AM   #2
1963c-10
1963c-10's Avatar
Re: What was the stock carb on a 66 C10 250cid?
Check out Tom Langdons site. Best guy I know for straight 6 mods
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-29-2012, 02:36 AM   #3
Heater63
Heater63's Avatar
An Offenhauser is your best choice for street use, easiest to run a small 4bbl, but they make triple 1 bbl, and I think dual 1 bbl setups. As mentioned, see Tom Landgons Stovebolt for info, as well as Inliners.org Langdons has a great split cast iron header type manifold, and Clifford Research has shorty and long tube headers.
292 + TKO500
Heater63 is offline   Reply With Quote
