Old 01-27-2012, 02:19 AM   #1
chevydrivor73
Fuel system setup for ls swap
I have seen lots of info about a return less fuel setup. The engine I purchased has a feed and return line with the regulator on the fuel rail. Is it as simple as running a feed line from the fuel pump up to the rail and a return back to the tank? I am about to order some fuel hose and want to make sure I am not missing anything. Thank you for the help.
chevydrivor73 is offline   Reply With Quote
Old 01-27-2012, 08:22 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Fuel system setup for ls swap
Yes, 3/8" high press hose to the rail with some type of filter and 5/16" return back to the tank.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-27-2012, 11:43 AM   #3
chevydrivor73
Your the man. I am thinking about running a fuel cell from summit and it has a -6AN vent fitting. Somebody mentioned something about a one way valve for this fitting. Does anyone know of a part number or what type of fitting/valve i need?
On a side note, is a special tool needed to remove the factory gm fuel lines?
Old 01-27-2012, 12:30 PM   #4
usmcchevy
usmcchevy's Avatar
Roll over valve, Like this:
http://www.summitracing.com/parts/ABT-TF350/
The line disconnect tool isn't needed, just squeeze the tabs push together than pull for the plastic kind. If you're talking about the metal internal finger kind, I use a small screwdriver and work them out.
Build thread
LSx Swap FAQ index
Old 01-27-2012, 01:58 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
the gm fuel line tool costs like $5 for a 3 size pack, I was hesitant at first but after breaking a plastic ones off, I sprung for the tool.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
