01-27-2012, 03:37 AM | #1 |
big or little wheels?
I am still towards the very end of my planning stage, but I'm not sure what direction I'm wanting to go. I've got the caddy northstar engine with a built 700r4 for powertrain. Not positive on a color yet, but like the idea of a pearl white. For wheels should I run steelies with ww tires, escalade 17 inch with white walls, or a 22, or even 24 inch wheel? I found a damn nice set of new 22s that may fit, but may need spacers to fit the hub. I can get them with tires for just over 1400... Any sugestions guys? Maybe pics of your large wheel setups
Posted via Mobile Device |
01-27-2012, 09:20 AM | #2 | |
Re: big or little wheels?
Furthermore, this is my personal opinion, for large tires (20+) to look good on these trucks they need to be lowered considerable. Just my opinions about a topic that YOUR opinion should really win the day... As for me, I'm going with 18's or 19's to clear brake components and that is the largest I want to go and I'd prefer the 18's over the 19's... Good luck friend! |
01-27-2012, 09:39 AM | #3 |
I prob should have mentioned. I am bagging the truck. I have a pb step notch, 21/2 drop spindles, I've plated the torsion bar lowers. Not sure how low ill be able to get, but eventually it will lay frame
01-27-2012, 10:04 AM | #4 |
On that note... Carry on then, the world is your oyster! The picture below is what I have in mind for when big rims look REALLY good...
01-27-2012, 10:44 AM | #5 |
I'm a fan of big AND little. Big on the back, little on the front. Makes it a lot easier to tuck the wheels in the front when you're aired out. Plus, I like the street machine look.
I'm really interested in seeing how the Northstar engine works out in a RWD configuration. That's a cool engine, and you can pick them up super cheap, compared to the LS motors, which are also a great motor candidate. You can make great power and have good mileage to boot. The LS isn't the prettiest engine, but how often do you drive with the hood OPEN?
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
01-27-2012, 10:51 AM | #6 | |
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
01-27-2012, 10:52 AM | #7 |
I scored the engine in a trade. Actually got the entire front clip of a caddy, and an extra running engine. In the beginning I was thinking I was going to have to have to get an adapter for engine to trans. Turns out the northstar with the exception of the lower right hole bolt up to a chevy 60 degree v 6 bellhousing. Soo the 700r4 out of a 2.8 s10 will work. Im building the trans to support the stock 300hp and then some more.
01-27-2012, 01:43 PM | #8 |
I'm with 63 C10, stock steelies all the way. One clarification though - stock 15" steelies from a 60-66 truck will not fit over disk brakes - if you're staying six lug, you'll need 71 and up 15" 6 lug wheels to clear the caliper. These were the stock wheels on 71-87 K10s. Stock 60-66 15" wheels have a taper on the inside that will interfere with the caliper.
