Old 01-27-2012, 03:12 PM   #1
WI65gmc
Electrical problem
Whenever I leave my battery hooked up and I go to start it the next day the battery is dead the truck is only wired to start right now none of the electronics are hooked up anyone got any ideas?
WI65gmc is offline   Reply With Quote
Old 01-27-2012, 03:47 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Electrical problem
You got a hot ground bud. Take the negative cable off and put a volt meter/light type probe between the battery neg and the cable, start pulling fuses until the draw disappears.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-27-2012, 04:21 PM   #3
WI65gmc
Thanks for the advice I'll look into it
Old 01-27-2012, 07:20 PM   #4
Clyde65
Clyde65's Avatar
I had a bad headlight switch that I used that to figure out what was happening. Good luck!
Clyde65
Rebuild of Clyde
support our troops!
Old 01-28-2012, 02:18 AM   #5
WI65gmc
so i looked into and yes the ground was hot it was actually getting the full twelve volts from the battery i played around with it a little and havent solved it yet also i have the main ground hooked up to one of the starter bolts that go up into the block so i was thinking maybe i should ground the black to the frame or the frame to the battery any suggestions?
Old 01-28-2012, 10:31 AM   #6
JimQ
JimQ's Avatar
First thing that came to my mind was a bad diode in the alternator.
Disconnect it (and insulate the main lead) and check for a draw again.
Q
'64 K20 327
JimQ is offline   Reply With Quote
Old 01-28-2012, 10:41 AM   #7
Fastrucken
Junior Member
Fastrucken's Avatar
Q
I second that!!!
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 01-28-2012, 10:56 AM   #8
ljackson
ljackson's Avatar
Changing the ground won't solve the problem. Following Clyde65's advice can. Give us a little more info. What year of truck? What type of charging system do you have? Could have a short in that system or the starter.
More info here:
http://67-72chevytrucks.com/vboard/s...ad.php?t=33198
60 - 66 generic wiring diagram:
http://67-72chevytrucks.com/vboard/s...d.php?t=378484
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 01-28-2012, 01:31 PM   #9
WI65gmc
The alternator is from an 86 pickup and I converted to get rid of the external voltage regulator the truck it's on is a 65 gmc
Old 01-28-2012, 01:51 PM   #10
jimmyboi082
start pulling fuses until it goes to zero volts and that will show you what circuit it is.
jimmyboi082 is offline   Reply With Quote
Old 01-29-2012, 04:54 PM   #11
WI65gmc
Pulled all fuses still nothing
Old 01-29-2012, 04:54 PM   #12
WI65gmc
Or I guess I meant I pulled all fuses and I was still getting voltage on the ground
Old 01-29-2012, 05:03 PM   #13
mud.man.rj
mud.man.rj's Avatar
Careful on the alt if it is a 10si stle with a flat plug at the back , the two spades looking at it from the back of alt the one on the left (or drivers side) is the keyed spade the one on the right or passenger side is live all the time the same as the output term at the back of alt. If you have the plug wired backwards the alt will still charge but will leave the regulator turned on all the time with the key in the off position so check the plug. Could also have a diode leaking in alt rectifier which will still charge some but will draw the battery down when not running. Put a voltmeter on battery terms cold without running get a basic voltage on a digital display and disconnect alt plug and alt wire to see if voltage increases if it does then your current draw is in alt.
mud.man.rj is offline   Reply With Quote
