Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-27-2012, 04:10 PM   #1
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
New engine build 406 SBC
Well as some of you know the old engine I had was a rip off from the builder.
So I started with what I had left for parts on the old build and bought a standard bore 400 block. Just found out that I got ripped again!!! the number 3 cap does not go to this block. I know I could installed new caps line bore and hone. But really for all of that extra work I am done!!!!
I bought a new Dart SHP block, along with a new crank. so here is the parts line up.
CP forged bullet pistons -1 CC dome
RHS 220 heads 72 cc
Howards 294/300 cam ( 241/247 @ .050) 545/565 lift
Howards retro hyd roller lifters
H beam cap screw scat rods
Scat crank.
Smith Bros push rods
Standard ratio roller rockers
Single plane high rise PP intake
750 race demon carb
MSD box and dist
We are setting comp ratio to 10.8.1 ..pump gas engine
Marv,... I know you told me so about the block, all good brother. SO the next time we see each other lets make it at the speed way..
I tried to use a stock block and in the end nothing but a huge waste of time. Unless you know that the engine ran, and did not spin the mains, or break the crank in a 400 the SHP block will save you some heart ache and money.
SO any one need a standard bore block that needs to have new caps on it and line bored?? 509 block, standard bore magged and ready to go LMAO first 100 bucks takes it.
GMR-PERFORMANCE is offline   Reply With Quote
Old 01-27-2012, 05:04 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: New engine build 406 SBC
im going to look at a 406 sb later today already built and broken in ,has few runs on it ,10.30s
how much is that 406 build costing ?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 01-27-2012, 05:42 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I might take it...let me check with my buddy in AZ to see if he's available to pick it up.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-27-2012, 06:32 PM   #4
GMR-PERFORMANCE
well a 406 that is running low 10's does not sound like a street engine but more of a drag engine. As for cost I would have to add it up, I re used the heads, intake, carb ign, v covers, etc from the old 383 build. But I would think some where in the 6000 + range ??
Old 01-28-2012, 09:54 AM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
I am not that guy that says "I told you so" Steve........... nope not me...
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-28-2012, 10:18 AM   #6
GMR-PERFORMANCE
LMAO too funny Marv. Well at least now I will have no over heating issues, the deck will be able to take the stress. You dont happen to have a single plate NOS kit laying around do you??? Since I am running lines and wires great time to add that in as well. The 8.2 rear end wont get me half way around the block now.
Old 02-02-2012, 10:29 AM   #7
GMR-PERFORMANCE
Well the new block is off to be prepped.
I have to say it is very nice, And I just read on the net that the dart block will give me 30 more hp and I think it should make about 578.37 HP @ 6400 so add 30. HA HA ( I am kidding guys, inside joke with Marv)
Marv I think it will be going on Becks dyno. ( unless you have an idea?) Once done you want to meet me in PHX?? for the tune on the little SBC
Old 02-02-2012, 11:40 AM   #8
Super73
Super73's Avatar
Good deal Steve, I really hope this one works out for you!! It should being what it is.
BTW, here is some info on the Eagle Field event I mentioned: http://eaglefielddrags.com/
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-02-2012, 01:10 PM   #9
Marv D
Marv D's Avatar
It's only worth the full 30 if you put the stickers on both sides LOL. Honestly the more solid cylinder walls will promote better ring seal and that always means more power,, errr umm less LOST power that is.. Just like the 'right' oil can add 3 to 5 to 10HP,, it all adds up.
Old 02-03-2012, 10:53 AM   #10
GMR-PERFORMANCE
Thanks guys..
I am pushing to get the truck done, The demon carb will go up for sale and a new SS Quickfuel will be going 830 vs the 750 I have now. The temps up here kill me not having a choke. 27 F coming into work, thought about taking the Harley in but way too cold for a 6 mile drive LOL
Super ..dunno you are gonna have to give the jump and two lengths and you off the bottle..
So Marv you in on the dyno session once its done??
Old 02-03-2012, 09:55 PM   #11
Super73
Super73's Avatar
The jump and two in an 1/8mile? Not sure you will need that much.
Old 02-03-2012, 10:00 PM   #12
Newtz67
Newtz67's Avatar
That block sure is pretty.
Newtz67 is offline   Reply With Quote
Old 02-04-2012, 09:26 AM   #13
Marv D
Marv D's Avatar
Originally Posted by GMR-PERFORMANCE View Post
Thanks guys..
Suuure Love to watch someone else beat the crap out of their new toys LOL
Old 02-06-2012, 10:51 AM   #14
GMR-PERFORMANCE
HA HA your right I dont NEED the two lengths but it sure wont hurt
Old 02-06-2012, 04:05 PM   #15
Super73
Super73's Avatar
I'd be nice and give you the 2 lengths, only if you give me the move...
Old 02-06-2012, 04:20 PM   #16
GMR-PERFORMANCE
How in the hell would that work, I give you the move you back out of it so I can get two and then you hit it again?? Sounds like bracket car crap to me..
Lets see how does that go, car leaves wheels up 600 feet out the cars stops like it has a chute open and then speeds up again, LMAO
Ok heads up, no lengths, your off the bottle and street tires ( not cheaters either real street tires.) drop the psi and let it rip. That is what I am running so even up, let the pretty girl drop the flag and we run em. I am working to get it done by the event, I have low hopes though, tone of stuff yet to do, but come fall sounds good for the west events. I am on track for mid to late june being done.
Old 02-07-2012, 12:15 AM   #17
Super73
Super73's Avatar
So wait a minute Steve, you already handicapped me with no bottle So much for heads up
I run a street tire, it's got a DOT marking on it with tread. It's called a Mickey Thompson ET Drag Radial. I even run them at about 18-20 PSI due to the wheel/tire combo and have put bunches of miles on them.
What next, do I need to start in 2nd?
I really want to see the truck at the event, so quit typing and get it done man.. Heck, Bring Marv with you!
Old 02-07-2012, 01:19 AM   #18
CSGAS
optomistic ah-so
CSGAS's Avatar
Q: Are you using retrofit roller lifters because you got them before the SHP block or because you prefer them over the later factory roller lifter setup (or something else)?
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 02-07-2012, 10:33 AM   #19
GMR-PERFORMANCE
I already had them bought. I do not have the stock OEM roller parts. so using what I got.
YEA YEA handicap.. HA HA I am all throttle no bottle .. with a 8.2 front load,.. HMM I hit it too hard it will be a rear load ....into the bed that is
Old 02-07-2012, 06:07 PM   #20
Marv D
Marv D's Avatar
Steve, check that the retro hydraulic rollers that you have fit the SHP block. The solid rollers have to be the tall, 'light weight cut away' to clear. I don't remember exactly why at the moment, and hydraulics being taller may not have the issue. but check it out before you get too long into the lifters you have and can't exchange them.
Old 02-07-2012, 06:45 PM   #21
GMR-PERFORMANCE
thanks a fast call to Dart should clear that up will let you know what they say
Old 02-11-2012, 12:37 PM   #22
GMR-PERFORMANCE
All good the howards are +.300 so no issues.
Old 02-13-2012, 06:29 PM   #23
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
RHS 220 heads 72 cc
Scat crank.
750 race demon carb
MSD box and dist
If you were a bit closer I'd be sending you the money and pickup later!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 02-14-2012, 11:49 AM   #24
GMR-PERFORMANCE
Block is bored and hone, zero deck. Looking at two weeks YEEEE HAAWWWW
Old 02-17-2012, 08:15 PM   #25
GMR-PERFORMANCE
Well I decided on a bit of power cheater dual system...
