01-27-2012, 10:15 PM | #1 |
69 rear end
I m spinning my gears trying to find out if there is a older truck rear axle that would be say 3/4 ton that used trailing arms and coil springs? I want to put a full floating axle in my 69 c-10. Not sure if i can or not.
https://picasaweb.google.com/oldtrains.martin011 Full timer rv'er and my wheels are always rolling along. |
01-27-2012, 10:19 PM | #2 |
Re: 69 rear end
Early C20's came w/truck arms & coils as well as leafs.
01-27-2012, 11:02 PM | #3 |
Re: 69 rear end
Early 60's or with the 67 up??
01-27-2012, 11:07 PM | #4 |
Re: 69 rear end
67-72 for sure. I work w/a guy that has a 68 3/4 ton 8-lug w/truck-arms & coils. Not sure what rear ends they had though & if they're worth rebuilding.
01-27-2012, 11:10 PM | #5 |
Re: 69 rear end
That will work!! Guess i am heading for the salvage yards tomorrow. thanks!! Dan
