01-27-2012, 11:18 PM | #1 |
Senior Enthusiast
60-63 Windshield Trim Differences
Does anyone know the history of the two different types of 1960-63 stainless windshield trim? Until recently I never realized there were two different designs. I picked up a set of the thin version and they measure ½” wide. They seem to have an equal amount of gasket showing on both sides of the trim like on a 64-66:
There is also a much wider style that appears to almost completely cover the gasket like these shots: I’m curious if one was originally a GMC design and the other specific to Chevy, or was one or the other a unique 1960 design that changed sometime during the 60-63 production run? Or maybe different assembly plants used one style over the other? I wonder why GM would go to the effort to redesign the trim when the 64 cab was right around the corner in regards to engineering/production lead time. Perhaps one style was easier to install? |
01-28-2012, 01:41 AM | #2 |
60-66 Nut
Re: 60-63 Windshield Trim Differences
It has been my experience that the wider trim was used on the GMC's.
01-28-2012, 01:58 AM | #3 |
I have a set from a 62 gmc and a set from a 66 chev and both are a 1/2" wide
ron |
01-28-2012, 08:06 AM | #4 |
I'm tuned in and very curious now. I bought a set recently and was planning to try to determin the "best" gasket to use and get it installed soon.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
01-28-2012, 10:37 AM | #5 |
Senior Enthusiast
I'm struggling with the best gasket problem as well. There are a lot of negative reviews but inconclusive on a brand without problems.
01-28-2012, 11:26 AM | #6 |
i tried a cheap gasket but the installer had no luck with it. so i broke down and got one from steele products then the install went good it took three people and two were pros ,1962 gmc with ss trim.
01-28-2012, 12:37 PM | #7 |
Enjoy your truck
If my windshield ever breaks I may consider driving without one rather than try to put in the gasket with trim again.
It is hard work but it looks great when it is in. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
01-28-2012, 01:51 PM | #8 | |
Senior Enthusiast
I've installed many windshields in years past and I'll probably be doing this one myself, but I know what I'm in for. The last time I tried on this truck I failed, and that was with a gasket having no trim. I'm hoping the skinny trim may be a little bit easier. I just love what the windshield and side window trim does for your truck. I'm hoping the stainless sparkle will add a bit more luster to mine as well. Last edited by markeb01; 01-28-2012 at 01:57 PM. |
01-28-2012, 02:03 PM | #9 |
Registered Loser
My 63 GMC had the thin trim. I bought a cheap gasket that the installer could not get the trim back in. Later on I got a Steele Rubber gasket and had to wait 4 months while it was on backorder. 2 different shops couldn't get that gasket in either so I ended up having them order a gasket without the trim.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
01-28-2012, 07:22 PM | #10 |
I pulled a wide trim off of a 60 Apache.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
01-29-2012, 12:02 AM | #11 | |
Senior Enthusiast
01-29-2012, 09:10 AM | #12 | |
Enjoy your truck
The difficulty lies in juggling the trim and keeping the gasket on the glass while installing in the opening. Four hands would have been better than two. Greg
01-30-2012, 09:55 AM | #13 |
It was my understanding that the wide trim was 60-61 and the thinner trim was 62-66. Could be wrong though.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
02-01-2012, 05:32 PM | #14 |
Just an FYI, there'll be a set of wide molding on Ebay.
02-01-2012, 06:04 PM | #15 |
didn't you post this before;
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help. |
