1406 edelbrock electric choke question
So I am wanting to know how to adjust the electric choke. I start my motor in the morning when it is cold and I need to really rev it up for like 10-20 sec before it will idle... and once it warms its ok, other than the hard start after she runs for a while. So basically turning the black chock cover forward (clockwise) is leaning the carb right (less fuel). And turning the black choke cover back (counter clockwise) is riching the mixture (more fuel). I think it is adjusted clockwise (forward pretty far. I was thinking of turning it counter clock wise (back) to the factory setting. Which I am told it will be like half way. Were are you guys setting yours and any thing else I should do.
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
Grandpa in the rustmobile...
Re: 1406 edelbrock electric choke question
Id have to look. Make sure its hooked to full 12v switched.
Whats your fuel pump pressure. Back when I had 8-9psi it was funny (hard) to start. id check your float levels as well...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Mine is set right in the middle, but that's with a 396. I'll second the fuel pressure, I had all kinds of issues before I finally dropped it down to 6 psi.
1992 Jeep Cherokee 4.0 AUTO 1972 C10 350/350 1971 C1500 350/350 1970 C20 396/400 |
ok thanks I will check those things out. I returned it to center notch, think factory setting and will sheck when cold
