Old 04-28-2003, 01:28 PM   #1
BUDDY
Global warming is a myth
BUDDY's Avatar
Weird electrical problems
OK Fellas, I need help on this one. I am doing a complete re-wire on my truck and I came up with this brilliant idea of using 6-way plugs, (like what you'd use for trailer lights), for the transition through the firewall for everything, headlights, taillights, marker lights and eventually the starter and HEI. Seems everything is going great, headlights turn on marker lights turn on, turn signals work at the RECEPTACLE on the firewall. HOWEVER, when I plug in the plug, (for the front harness), to the receptacle, the flashers or turn signals will work, but AS SOON AS I turn on the marker lights &/or the headlights, the flasher stops. I am really confused and I have checked and re-checked my connections to make sure they are good and not crossed.
I have it wired as follows.
RT - right turn (green(rear) & dark blue(front))
LT - left turn (yellow(rear) & light blue(front))
TM - marker lights (brown (both))
ST - High Beams (light green)
AC - Low Beams (tan)
GD - Horn
I have an idea that the plug may be getting overloaded, and causing some problems, which I might remedy w/ a relay in front of the receptacle to step down the current into it and then another relay under the hood to step it back up for full voltage to the lights, but that's a LOT of unneccessary connections I think. It may be the only way, but I hope to get around this some other way. I'm really at a loss at this point.
If any of you guys has ANY idea about why this would be happening I'd love to hear from you.
thanks in advance,
Buddy
BUDDY is offline   Reply With Quote
Old 04-28-2003, 01:53 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
there two filiments in the park-blinker, are you sure you wired the park to the park and the blinker to the blinker,otherwise if you have the blinker filiment lit up as a park you wont be able to see the park blink for it will be dimmer?
sneakysnake is offline   Reply With Quote
Old 04-28-2003, 02:06 PM   #3
andyr354
Check your grounds to the marker lights. I had a similar problem with my rear lights. The marker or the turn would work, but not at the same time. Turned out the ground was bad, cleaned up the mounting surface and all was good to go.
Run a wire right from the negative of the battery to the frame of the light just to test it out.
1970 C10: 2WD, LWB, 350, 350 auto, Headers, Duals, Edelbrock 1406 with 2101 intake, and optional rust.
andyr354 is offline   Reply With Quote
