Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-28-2012, 01:58 AM   #1
pacman1967
pacman1967's Avatar
Gear Question for the Racers Smarter then myself
I am building a 350 with a weiand 142 blower, the cam is .488/.510 114LSA 234/244 degrees of duration and a Holley 750cfm carb. I am running a turbo 350 tranny, with stock gears. I am running a 315/60/15 M/T ET Steet tires out back. I am not sure what gears to run in it. I wanna be spinning about 5500rpm thought the lights on a 1/4 mile track. I was thinking about a 3000rpm stall also. Its going into a 85 shortbox. Its gonna see some street use but mostly gonna be my track toy. Any help and information would be great. Thanks in advance.
Marcus
1985 swb C10 Supercharged357/TH400
1972 lwb C20, Grandpa Al's Truck
pacman1967 is offline   Reply With Quote
Old 01-28-2012, 08:55 AM   #2
Blue Rat
Re: Gear Question for the Racers Smarter then myself
What does it turn now through the lights rpm wise, an what gear?
Blue Rat is offline   Reply With Quote
Old 01-28-2012, 09:44 AM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Making some assumptions...... Power wise I think your going to be capable of mid 12's is a total WAG. and probably around 105-110ish.
A 315-60 is a 29.7" tire
and a decent street / strip convetor is going to have ~10-12% loss in the traps
that assumed, the math says....
3.73 gear = 4800-5100 in the traps
4.10 gear = 5300 - 5600 in the traps
More importantly,,,, 4.10's will be around 3500 on the freeway at 75mph, where 3.73's will be about 3100.
Without an OD it's always sacrafice somewhere....
3.43 or 3.73 would be my choice for a street driver,, 4.86 for the track so you get that thing up around 6600-6800 in the traps so it can make some power
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-28-2012, 07:55 PM   #4
pacman1967
pacman1967's Avatar
Well I haven't had the truck to the track yet, and I wanna stay at around 5500prm to be safe and keep away from possible valve float. The blower starts to loses effeciency after 5500rpm do to heat and that toward the top of the cams rpm range also. Thanks Marv D. and 12's is the goal with this little set up, and out here in rural nebraska we don't have too many freeways, this ol gal will never see over 65 on the high way.
Marcus
Old 01-29-2012, 05:12 AM   #5
pacman1967
pacman1967's Avatar
What is everyone's opinion on B&M Holeshot convertes? I was looking at a 3000 rpm stall.
Marcus
Old 01-29-2012, 01:20 PM   #6
RatPwrd72
RatPwrd72's Avatar
I vote 4.10's for the rear...
I think there are better converters out there than the B&M's. I'd be on the lookout for a used, high-end unit.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 01-29-2012, 02:55 PM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i dont care for b&m torque converters ,tci ati ,monster ,steve evans custom made ,detroit converters for some others
im running everything tci on my 72 turbo 400 transbrake
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 01-29-2012, 08:21 PM   #8
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
I think that a set of 3.73 would work the best for all around use. Marv beat me to the math. However if the bug really bites you and you want the truck to really hook a set of slicks will get you there. However they are going to grow a fair amount, thus more gear is the safe bet, but street use suffers at least hwy driving will. since you said not much street use but a track toy, hit the gearing for all you can. 4.10 would be my choice. I love gearing!!!
A good convertor is worth its weight in gold, vs the el cheapo ones. And a ask me how I know deal is do not run one with out a anti ballon plate, and no trans brake on the stock TB 350 cast hub... not unless you want to see inside the trans from out side that is.
Gearing is the starting point from there you get to play with stall speeds.. advertised stall speeds are just that ,... its all about the set up. 3000 is not much really but never ran that small of a blower on a sbc either.. I ran a 4200-4500 for my old 355 in a s-15 truck with 4.56 gears most strip than street.
A blower will push the power out past what the cam is stated to do. In fact a blower cam needs duration and that is about it. Open the door fill the cylinder and make boost. We just complete a 120 CI harley engine with 14 lbs of boost on a pro charger it makes 222 hp and 175 tq. So do the math on what you can do with that set up. I ran a very large duration cam shaft to allow more time to fill the cylinder. take that and the car stuff I have done it has always come back to amount of duration vs time to fill the cylinder as rpm's increase.
Good luck on your hot rod truck sounds like its going to be fun.
GMR-PERFORMANCE is offline   Reply With Quote
Old 01-30-2012, 01:42 PM   #9
Marv D
Marv D's Avatar
I tell ya, for convertors it's hard to beat the Jeggs house brand. We put a $220 Jeggie 3600 advertised stall in a buddys 74 Nova with a 434,, he's footbraking to 10.3's. Stages at 3000, Says best he can see on the tach it flashes to 3800-4000. It's been in the car for 5 years spinning a 10 year old Hughes street/strip TH350 . The 3500-3800 is a loose convertor for street, but they have tighter ones too.
http://www.jegs.com/p/JEGS-Performan...50793/10002/-1
Old 01-31-2012, 12:42 AM   #10
pacman1967
pacman1967's Avatar
Thanks Marv, I will look into that Jegs unit and it will help keep me in budget. Thanks for all the info guys.
Marcus
Old 01-31-2012, 08:29 AM   #11
hotrod 80
mini truck racer
hotrod 80's Avatar
With the tall tire i vote 3.73 . My buddy has the 3500-3800 Jeg's in his 67 Camaro and it works good .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 02-09-2012, 01:05 AM   #12
pacman1967
pacman1967's Avatar
Well guys here is the little jewel that caused all the questions, thanks everyone for all your help, I am going to be useing a 4.11 gear set and the jegs stall that Marv D. suggested.
Marcus
Old 02-09-2012, 09:23 AM   #13
Marv D
Marv D's Avatar
Those little 144 blowers are pretty nice on the street is what I hear (I have never had anything with mechanical boost) Might want to be a bit conversative with the stall. Making more torque dow low with the boost your going to drive through the convertor more than you would n/a. e.g. what may be a 3000 stall behind a normallly aspirated small block might go 4000 with 5psi force feeding it. Blower motors are agressive in the torque department
Old 03-10-2012, 02:26 AM   #14
pacman1967
pacman1967's Avatar
well I ordered a jegs 2700-3000 stall we will see what happens
Marcus
Old 03-12-2012, 10:38 AM   #15
GMR-PERFORMANCE
Should work very well. As Marv stated the Tq input is what makes the convetor work, its hard to nail it dead on the first go round. With a blower motor shooting under for stall is a good bet for normal use. ...
