reverse lights, not coming on at right time.
its an 84 k10, when i put it reverse (like actually feel the tranny shift into reverse) the reverse lights dont come on. but when its in reverse if i pull down on the shifter a slight bit, not enough to make it go in neutral though, the lights come on. but if i adjust the shift linkage, it wont go into other gears right. how can i solve this.
thanks. |
Re: reverse lights, not coming on at right time.
I believe the switch on the column is adjustable. It is located on the tube below the dash
![]() Join Date: Jun 2009
adjust your neutral safety switch...located on the lower column under the dash..with the truck off and ebrake on, put in reverse and adjust the switch til the lights come on..
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
thanks
