01-28-2012, 10:35 PM | #1 |
Gap between cab and bed
Can anyone tell me what the gap is supposed to be between the cab and the bed on an 86 fleetside?
I have been assembling the truck for the last test fit before I finish the body work after a frame off rebuild. I want to make sure the cab and radiator support are adjusted right and tightened before I pull the sheet metal off. This is what I got to work with. New frame 2wd converted to 4wd, new cab rebuilt and painted, different bed, radiator support fenders and doors are off my old truck. Thanks, Zebb |
01-28-2012, 10:54 PM | #2 |
Re: Gap between cab and bed
I can't help you with your question, but your truck already looks nice and I really like your stance. Good luck with truck.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
01-28-2012, 11:46 PM | #3 |
thats a good question. i want to know that too. on my 74 the gap is wider on one side than the other. i need to know what to do about that.
01-29-2012, 06:40 AM | #4 |
BAD BOW-Silverado XST
You have some adjustment. Loosen up all the bed mount bolts. Use a ruler to set the gap evenly on both side. Bolt it down when you have it set. I think the gap on mine is two fingers......
01-29-2012, 10:38 AM | #5 |
Robert Olson Transport
im going to say approximately an inch and a half to two inches
01-29-2012, 11:05 AM | #6 |
Thanks guys.
My plan is to set the bed square with the bolt holes centered then gap the cab to the bed and square the cab. It's not far off from that now and I guessed about right on the gap. |
01-29-2012, 11:55 AM | #7 |
I agree with everything that has been said so far except I would square the cab first, because that will affect your front end squareness (thereby affecteding fender-to-bumper gaps and also your hood-to-fender gaps). Fitting the bed is easy by comparison, and doesn't affect anything (other than the cab/box gap).
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-29-2012, 12:32 PM | #8 |
Just came in from the garage - mine is about an 1.25" on the LH side and about an inch on the other -
My cab has never been off but the box has been off about a hundred times - K
01-29-2012, 12:48 PM | #9 | |
01-29-2012, 05:44 PM | #10 |
On my 83 fleetside it is 1 1/2" from the back of the cab to the front of the bed.
