01-28-2012, 10:43 PM | #1 |
BF Goodrich t/a question..
Im running a american racing wheels -19 offset 15x8 on the front of my 74 swb gmc with 265/50/15 BF Goodrich T/A tires. I have a little rubbing since I have a 4 or 5 inch drop. I would like to get tires that arent so wide. Maybe a 235 or 245. My question is does BF Goodrich make these sizes? On thier website they dont have many T/A tires with a 50 aspect ratio. I dont want to get 60 aspect ratio. What other brand of tire is most similar to BFG's T/A's? Thanks
01-28-2012, 11:05 PM | #2 |
Has more rust than truck...
Re: BF Goodrich t/a question..
I use this:
http://www.1010tires.com/tiresizecalculator.asp It allows you to compare sizes and it will list the tires available in that size at the bottom. I'm sure it doesn't list all brands, but gives you a start. |
01-29-2012, 12:05 AM | #3 |
I always go to tirerack.com and search by tire size.
01-29-2012, 01:37 AM | #4 | |
01-29-2012, 03:05 AM | #5 |
The reason I dont want to get 60's is because the rears are 295/50/15 and they are pretty new. I just want to change out the fronts and want them to match.
01-29-2012, 03:52 AM | #6 |
01-29-2012, 04:03 AM | #7 | |
01-29-2012, 03:15 PM | #8 | |
01-29-2012, 03:30 PM | #9 |
At the body shop.
295/50 and 245/60 look good. Together
" That didnt make it any newer " " Dont antique the equipment " |
01-31-2012, 12:37 AM | #10 |
If the fronts are 60 and the rears are 50 wont it look a little uneven? I currently have 265 50 in the front and 295 50 in the rear and to me it looks awesome. The fronts rub just a little bit. I guess ill just buy some spacers. Why doesnt bf goodrich make 245 50 to match the 295 50 or 295 60 to match all the 60 tires?
Posted via Mobile Device |
01-31-2012, 01:42 AM | #11 |
At the body shop.
Ill look when i get home. Im sure i have a pic with 295 and 245s on 8s and 10s if you go back to my old posts youll see a pic of it. The idewalls are all most identical.
01-31-2012, 08:26 AM | #12 | |
50% of 295mm = 147.5mm 60% of 245mm = 147mm Pretty close....
01-31-2012, 03:32 PM | #13 |
needs more $$$
It took me a long time to understand this about tire sizes for some reason...
1970 2wd Blazer |
01-31-2012, 06:22 PM | #14 |
cool I guess ill go buy some 245 60, thanks guys for the advice.
