01-29-2012, 08:52 AM | #1 |
Fuel gauge wont stay still!!!!!
with all of the lights off and no turn signals blinking, my fuel gauge is fairly accurate. However, when I turn the head lighs on the gauge will drop almost half the span of the gauge.
I.E.- if is says the tank is full with the lighs off, when I turn the lighs on it will drop to half the half full mark. Also, if I introduce the electrical current of the turn signal, it will then fall even more and jump back to the half-full mark corrisponding to the blinking of the turn signal. What is going on here??? |
01-29-2012, 11:48 AM | #2 |
Re: Fuel gauge wont stay still!!!!!
Bad ground on the gauge cluster. It's drawing some of the resistance of the fuel tank sender to ground back through causing causing it to fluctuate. Check for corrosion on your pin connectors and or throw an extra ground wire to the cluster case back to the firewall. Assuming you have a body ground off the cab to the frame and one off the negative battery post to the body too.
Also check that someone has not tapped a wire (looking for power or a ground) to that gas tank sending unit wire from the gauge to the sending unit in the tank.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
01-29-2012, 02:19 PM | #3 |
thanks man! i had an idea about an insufficent ground problem, but did not completly understand the science behind it all. You've really helped me out!!
