Old 01-29-2012, 11:25 AM   #1
OKGMC4
OKGMC4's Avatar
5.3 multiple misfire, any advice?
2001 5.3l with cylinders 4 and 6 not firing. Engine light steady blink. No spark at the wires with timing light. I traded coils and same result. I traded out the coil banks from side to side and same result...so it can't be coils or coil harness. I've seen people suggest egr, plugged cats, bad fuel regulator and stuck injectors. I don't have egr or cats, and I assume since the no fire condition is on two cylinders and not random it can't be regulator or injector related. Leaking intake gasket could do it normally but it shouldn't cause a no spark condition. Any thoughts?
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 01-29-2012, 12:12 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 5.3 multiple misfire, any advice?
Pull the plugs on 4+6, are they wet? Check for spark while while you have the plugs out. My guess is going to be plugged injectors.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-29-2012, 01:04 PM   #3
OKGMC4
OKGMC4's Avatar
That is entirely possible, I had to unclog them to get it to start. It had been sitting for 4 years and all 8 were stuck. However, would a clogged injector cause the coil to not fire? Timing light shows no spark at all on those two. Just for fun I checked the fuel regulator and it was putting gas in the vacuum line. I ran and got one and installed it and now I have a much smoother idle (smells less rich too) but I'm still not seeing fire on 4 and 6. Could a bad injector actually cause that?
Old 01-29-2012, 01:23 PM   #4
OKGMC4
OKGMC4's Avatar
Ummm... I don't get it. I checked plugs 4 and 6 and they were a little wet. I pulled 2 just to verify they looked the same. Then for grins I swapped out 6 and 2. The problem followed the plugs. Now 2 and 4 misfire. Is it really possible I just have 2 bad plugs? They were new NGK, and I know everyone says to run delco but I've never had a problem with NGK. I'm going to run out and get a couple and see what happens.
Old 01-29-2012, 01:51 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
hows your plug wires
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-29-2012, 03:30 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
clogged injectors would provide no means to shut off the ignition system; I'd think you'd throw a error code for fuel injector of possibly 02 (if the mixture was out of whack from stuck injectors).
Check your plug wires or swap the coils, see if it changes.
NGK plugs are more than fine; if you start needing a different heat range, I'd say 75% run NGK's
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-29-2012, 03:59 PM   #7
usmcchevy
usmcchevy's Avatar
Ok, I didn't read your first post very well, sorry. Sounds like you have it narrowed down to plugs and wires. I haven't ever had a problem with NGK, I had a set of bosch platinums just start to give out for no reason a few years ago.
Build thread
LSx Swap FAQ index
Old 01-29-2012, 04:07 PM   #8
OKGMC4
OKGMC4's Avatar
I got two more plugs and they are firing fine now. I've seen other brands bad out of the box but this is an NGK first for me. Idles smooth now. I'm sure a new regulator that doesn't dump gas down the intake helps! Thanks for all the help...on to the next problem...
