i want to see all LIFTED 4X4's
All Pictures of lifted 4X4 trucks 73-87
Ill start by putting mine with a 3inch body lift. i no its not much but i want to lift it 4 more inches. ![]() ![]() |
6.0 powered square
Re: i want to see all LIFTED 4X4's
http://67-72chevytrucks.com/vboard/s...d.php?t=368678
theres more in the 4x4 section
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
heres mine 1989 GMC Crew Cab Dually 8" SKYJACKER 325/80R16 FALKEN WILDPEAK A/T
Doug 66 4x4 GMC Suburban 76 4x4 Chevy Shortbed |
My 83 shorty with a slight lift on 31.5 x 15 BFG All Terrians.
nice
Chevys Kick A$$
Nice looking crew cab dually looks pretty badass with the lift and tires! Keep up the good work
![]() Posted via Mobile Device
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Heres a couple pics of my '87 lwb with 4" lift on 33" tires
![]() Shes a bit dusty in this pic ![]() And I gotta show er off clean, just looks so much nicer imo ![]() ![]()
1987 Chev V10 Custom Deluxe 355tpi, 700R4, 3.42s in 10 bolt axles (for now!), new Auburn Posi in rear, 4" lift on 33s. ![]() |
getting ready for paint and a low mileage duramax
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE |
83 k10
10 in lift 38 in tsl swampers 383 stroker |
![]() Join Date: Aug 2011
Here's my 83' with 3" lift and I just bought the 79' with 6" lift, $800.00.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
hartbraker: what lift and tire size?
allchevy58:what tire size on the 83?
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s |
#13 |
My 84 before i tore it apart again.
![]() ![]() And now the new frame to rebuild on. ![]() |
#14 |
Had a spring shop add-a-left and rearc original springs, 33X12.50X16.5 in the picture, just bought new 16X8 Mickey Thompson II's with 285/75R16's.
#15 |
http://67-72chevytrucks.com/vboard/a...1&d=1328243042..
My 85 all orig paint 10'' lift and 38's |
#16 | |
#17 |
The tire size is 36"X13.5" Irok Radials on 20" polished aluminum wheels
#18 |
#19 |
riz, nice blazer, here's mine
1990 k5 blazer 1990 gmc jimmy 1949 1300 p/u-sold 1977 bbc skylark 96 roadmaster 06 9c1 impala |
#20 |
![]() '83 K20. 6" suspension, 3" body, 38x15.50 MT Baja Claw Radials.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
#21 |
#22 |
Between rims, tires, and mounting/balance I believe I had around $3,000. I wanna say the rims were around $240 a piece. Tires were so outrageous it wasn't even funny.... But I'd do it over again in a heartbeat. I am more than pleased with how well these tires do in the mud and how they have worn thus far on the road as I tow A LOT of firewood in a 7X14 gooseneck dump trailer holding about 15,000 lbs. Tows like a champ.
Thanks a lot for the comment on the truck. A lot of time has gone into this one and I'm getting ready for paint now... I'll be sure to have a thread for my progress whenever the money pile gets big enough to begin.
#23 |
Not to hijack the thread but does anybody have pictures of specifically 6 inch suspension lifts with 35s? That's what I'm going for with my truck
Semi professional heavy equipment operator Amateur mechanic |
#24 |
6 inch with 35's will give you a look of SMALL tires, as the tire will not fill the wheel well. The only difference between the brown truck and what youre requesting is 36" tires instead of 35"... so it's pretty close
#25 |
Well my buddy had an '81 Silverado with a 6 inch lift and 35s that I thought looked pretty nice. Just curious what other peoples trucks look like. He sold it to his brother who put a 3 inch body lift on it with the same 35s and I think that just looked dumb. I might be able to find some before and after pictures.
