01-29-2012, 07:01 PM | #1 |
HELP with electric choke
Hey all, I just installed a Holley 600cfm carb,and need to know where the + lead on the choke should be getting power from. the guy I got the carb from said "run it off the + side of the coil cuz it's the closest hot lead to the carb" is this o.k. or should I find a better/safer hot lead? Where do you guys hook it up to?
Thanks in advance.
Brian. '70 GMCHEVY '51 chevy "tin woodie wagon" IF YOUR CONFUSED I'LL USE smaller WORDS! |
01-29-2012, 07:28 PM | #2 |
Active Member
Re: HELP with electric choke
I've heard not to run it from the coil or alternator. Find a keyed ignition circuit that gives you 12vdc when key is on and zero volts when off.
01-29-2012, 07:40 PM | #3 |
like off the fuse box?
01-29-2012, 07:45 PM | #4 |
I run mine off the coil. It doesn't draw much current.
Someone else might have an idea why it's better to run it off another circuit, but I can't think of one. |
01-30-2012, 07:58 AM | #5 |
1969 Custom 30 wrecker
On mine I run a wire from the choke back into the fuse box. (something that is only hot when the key is on)
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
01-30-2012, 10:55 AM | #6 |
Fuse box is good, wiper motor is another source, as others mentioned, hot ONLY w/ key on...
Make sure carb is grounded to intake, and intake grounded to body, body to frame. Can't have enough grounds. |
