Old 04-28-2003, 06:19 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Cutting Dash Question???
I am thinking about cutting my dash to put in a cd player and was wondering that if i did this how do you mount the cd player? Theres nothing there. Can you please let me know. Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 04-28-2003, 06:27 PM   #2
Solarus1981
I have a cut dash in mine... but if you have a rust free uncut cab... there are people that will maybe trade you for one that is. I know I would!
'67 LWB C-10, 406 cid th350, dunno what rear end
Looking to rent a house in Puget Sound area, anyone have one?
Solarus1981 is offline   Reply With Quote
Old 04-28-2003, 07:28 PM   #3
chevykid1969
chevykid1969's Avatar
most cd players come with a metal bracket thing that once you cut the hole it slides in to support the cd player in the rear. there are also little tabs on the bracket you push out to hold thewhole thing inplace. i did mine last year and it worked fine.
chevykid1969 is offline   Reply With Quote
Old 04-28-2003, 07:56 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
It's your truck but I wouldn't cut it to put a stereo in, unless you've already or are planning to do other body mods. Takes away from the value of it's originality IMO. There are other alternatives and I'm sure somebody can help you there.
This will spark a debate
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-28-2003, 08:36 PM   #5
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
There's not much on our old trucks that makes me sicker than to see where someone "Butchered" the dash to install an aftermarket radio. There are several places that you can buy a new AM/FM radio with the outputs for an external multi disc cd changer. You can then mount the cd changer in the glove box, console, under the seat, etc... and not have to cut up your dash. If it were mine (unless your building a complete custom truck) I wouldn't cut up the dash.
Robert
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Old 04-28-2003, 08:54 PM   #6
casey
casey's Avatar
touchy subject, cut or not to cut, here we go again, I'm a non cutter, but its your truck, and if you cut it for a cd player to answer your question hotrod929 I think you might need a strap on the back of the deck to hold the weight of the deck on the back of it, make sure you measure it a few times before you cut. as far as cutting it goes after looking at efabmans post on welding in repair panel, fixing that dash would be a peice of cake, there probably going to come out with a dash repair panel soon if they don't already make one
casey is offline   Reply With Quote
Old 04-28-2003, 09:04 PM   #7
Green72GMC
Green72GMC's Avatar
They way I look at it is, it is your truck and no one elses so do what you want that makes you happy. I cut mine and I just bent the tabs up on the cd player support and I have hit many a hole and it is still in there.
1972 GMC SWB, 305 powered
1980 diesel VW pickup, Needs a Heart Transplant
1997 Toyota Taco
The Second Amendment is in place incase they ignore the
others.
Green72GMC is offline   Reply With Quote
Old 04-28-2003, 09:19 PM   #8
XXL
Seņor Member
XXL's Avatar
Open that baby up!
Just cut small, file to size, then the radio can goes in and the tabs get bent back to hold it in place. After you get it mounted, take a few seconds and attach a backstrap to the back of the radio (it has a threaded place for just such a thing) and run it to the factory backstrap catch on the firewall just behind there. It will make the radio more solidly mounted.
XXL is offline   Reply With Quote
Old 04-28-2003, 10:48 PM   #9
greasemonkey
greasemonkey's Avatar
What XXL said, cut it small and file. I bent the tabs back on mine and it is really solid in there. I had a strap on the back but it came off and started rattling like crazy so I took it off. Cut it!!!
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 04-28-2003, 11:08 PM   #10
1969 GMC
1969 GMC's Avatar
I put mine in the glovebox and use a remote to change tracks etc so I don't have to lean across the truck while driving. Works fine for me.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-28-2003, 11:59 PM   #11
HotRod929
HotRod929's Avatar
1969 GMC - You got any pics/info. on your setup. Would really like some pics. Thanks
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 04-29-2003, 12:01 AM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I cut mine and installed the stereo like mentioned above, no strap or anything. It does not move, rattle or skip.
Funny, (almost) everyone will cut the yellow wire out when they install HEI, most ppl will cut the harness and install an internally regulated alt...but stereos seem to cause problems...
These aren't Yenkos or Nickeys...
Old 04-29-2003, 03:02 AM   #13
Piston
Piston's Avatar
I cut my no A/C '71 cab to install a cd player but now that I have 2 A/C trucks with uncut dashes, I've moved over to the "Don't Cut it" crowd.
Piston is offline   Reply With Quote
Old 04-29-2003, 08:43 AM   #14
greasemonkey
Traitor.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
Old 04-29-2003, 09:46 AM   #15
CPNE
Resident Curmudgeon
CPNE's Avatar
Before I start, let me preface this by saying, it's your truck and to each his own but here's why I won't:
With some upgrades there are no alternatives including HEI and one-wire alternators, the stock design must be altered. And with many changes if someone wants to revert back, it's relatively simple. Once a dash is cut it's not simple (for most of us) to restore it to stock.
Furthermore there are many stereo alternatives, from alternative locations to post-style stereos with modern components that bolt right in. The "cut it" argument here is that the post-style radios are overpriced and produce poorer sound quality. True, but unless you are investing in sound-proofing and all the accoustical changes required to actually here the difference, the argument falls short. If you've invested in the acoustics to that degree chances are you've made radical modifications anyway, so a dash change is of little consequence in the big scheme.
Not that resale value (as parts) should be a major consideration (after all who builds a truck expecting to part it out) but in my 6 years experience selling parts, no one was enthusastic about modified sheetmetal. As a matter of fact, nearly everytime I advertised a cab for sale, the number one and 2 questions are "where's the rust?" and "is dash cut?". That, to me, speaks volumes about these type of alterations. BTW, same with speaker holes in doors!
Many people when they sell a vehicle will remove their custom stereo for the next project. If you cut you are forced to leave it in, buy a cheaper replacement, or sell it with a gaping hole in the dash.
I don't mind disk brakes swaps, moderate lowering, engine/tranny swaps, aftermarket a/c, aftermarket wheels, convenience upgrades, detailed engine compartments, performance upgrades, etc. So I'm not a strict purist.
As you may have guessed I don't like chops, radical drops, bags, roll pans, louvers, shaved emblems, smoothed firewalls, seats that look out of place, small or radical steering wheels, wild customization, 88-98 beds, non-stock grilles, electronic gauges, one-piece windows, fuzzy dice, and cut dashes. But I respect you and your creativity if that's what you prefer!
My 2 cents on this.
I've hijacked this thread enough, so go here to register your opinion on this
Old 04-29-2003, 12:59 PM   #16
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Mine was cut by the previous owner and they did a crummy job. If you decide to cut it, just take your time. It is better to have to cut again larger than have to try and weld material back in place. I bought a radio delete and I'm going to cover the big hole in the dash and put the stereo in a tuffy locking console.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-29-2003, 05:49 PM   #17
Piston
Piston's Avatar
Originally posted by greasemonkey
Traitor.
muhahaha
