man. brakes to power help
where can i find a kit to convert to power brakes? from what i have found i will need a bracket to mount the booster to the fire wall and a diff rod that attaches to the brake pedal.
![]() Join Date: Oct 2009
Re: man. brakes to power help
you'll find a good adapter and lotsa info on this link - CaptainFab makes this nice bracket. He can tell you more about any possible required mods, if any - depending on what year your truck is and whether drum/drum or disk/drum, etc... http://67-72chevytrucks.com/vboard/s...d.php?t=347484
Are you converting from manual drum/drum to power drum/drum? If so, this is what I did:
- Pulled booster bracket and pedal push rod from parts yard for like $15 (cleaned and painted) - Purchased remanufactured booster & master cylinder (cleaned and painted) - you can use the same master cylinder if it's in good condition, but I opted to replace. - Replace pedal push rod firewall boot. I would strongly recommend the following: - Inspect wheel cylinders, brake hardware and drums (I opted to replace my wheel cylinders) - Replace brake hoses - It's a really good time to inspect all of your brake lines (I chose to replace mine because the front lines were pretty rough. This is a pretty easy to do. That said, good brakes are obviously very important, so I would recommend doing it right the first time. Also, you will also likely need to adjust your brake light switch when you're done.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, FleetsideUpgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
i bought the truck with front disc but no power brakes, is it common to have front disc without having booster?
My truck is disc front and no power. I could be wrong but I think it was pretty common. I am just getting the brackets etc from the junkyard and adding a booster, m/c, and proportioning valve.
Jeramy CURRENTLY OWN, 72 c10 project/driver 2010 Kia Forte Koup SX daily driver 88 cherokee wheeler and dog hauler 2001 drz 400 Miss my 2004 firebolt (stock) and 2001 superhawk with a ton of modifications and many other previous vehicles. |
1969 Custom 30 wrecker
Personally, I'd hit the junkyard and get a complete unit with all the brackets and bolts. This will also show you how to install.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Here is a link to the FAQ on the swap. Took me less than an hour to do.
http://67-72chevytrucks.com/vboard/s...ht=power+brake
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
| Bookmarks |
