01-29-2012, 09:26 PM | #1 |
Robert Olson Transport
What did you get done 1/29/2012 edition
truck is getting ready for the bed to come off and have the rust there repaired..the nose is going back on and its getting cut in and the rest of the interior is brought down to the upholstery shop for dyeing.. two teaser photos...and a pic of the latest catch
01-29-2012, 09:39 PM | #2 |
Re: What did you get done 1/29/2012 edition
Nice work and nice deer!
I managed to pull the drive shaft out, pull the transmission tail off, Reclaim my speedometer gear, bolt it all back up, install the new speedometer gear housing, and now Im hopeful I did it right and all my leaks will be gone!!!
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
01-29-2012, 09:57 PM | #3 |
I put in another re-man power steering pump today. Got everything bled, and it worked fine. Then I went to back the nose of the truck out of the garage. I made it 5 feet and my fuel pump quit. Sometimes I think this truck is trying to kill me. Thank God I had a brand new one waiting. Hey, at least it happened 5 feet from my garage instead of 100 miles away, like what would usually happen.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
01-29-2012, 10:23 PM | #4 |
Just here to tinker
Got my hucaps installed finally!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
01-29-2012, 10:26 PM | #5 |
01-29-2012, 10:47 PM | #6 |
The Peacemaker
I only had one beer before this happened, I promise!
I'm currently attempting to be the body man...we are sanding....and sanding...and sanding, man do I wish I had a media blaster.
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
01-29-2012, 11:09 PM | #7 |
Got the last bits of the motor installed and got her fired up after almost a year. Then started wiring up the electric fans and temp gauge.
Posted via Mobile Device |
01-30-2012, 12:56 AM | #8 |
got the hideous big rear step bumper off of my 82 stepside.
boy what a task it was! has to spend half an hour with an air chisel to get a couple off and the rest were seized on there but eventually came off with the impact....2 hours o remove the bumper.dammit. and got my new 4-row big block radiator tanked and painted.like new!
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
01-30-2012, 01:20 AM | #9 |
Got the 305 back together and it and the tranny back in the shortwide. Found out none of the crossmembers I have fit the tranny so I threw in the towel for it today.
82 chevy longbed(grey truck)first truck when i was 15! |
01-30-2012, 09:03 PM | #10 |
Performed a heater core - box swap on my 75 (top) by swapping in reworked one sourced from '78 (bottom). The 'swap' went through OK. It's amazing how much crud accumulates inside these things over decades! Now I have functioning heat and defrost. However, as soon as buttoned up heater system alternator went into a quasi charging mode ~ putting out barely 13Vdc vs. normal 13.8 to 14.3Vdc. Looks like another bridge rectifier went south!
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
01-30-2012, 09:12 PM | #11 |
Got the humps cut out of my floor. so I can install some newer seats. havnt figured out how to mount them in just yet, But I will
01-30-2012, 11:25 PM | #12 |
I drove the burb to performance shop to have diff installed in front with new gears. Talked to him about doing my next exhaust for the headers that showed up today.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
01-31-2012, 01:31 AM | #13 |
01-31-2012, 03:55 AM | #14 |
Bolted in my aluminium bed floor, shot primer on the light bar and test fitted bar/lights on the bed.
Put new brakes in the rearaxle, and punched a hole in my forehead when a spring slipped off one of the hooks. Finaly took off manifolds and drilled out 2 broken bolts, now I can start fitting my new exhaust. Found a set of 18" rims that might end up under my truck if the seller can make up his mind about acualy selling (why do people advertice if they are not sure?)
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
01-31-2012, 10:01 AM | #15 |
GoatLube Experss
friday I fix'd a small generator for ANP, they told every one who fix'd it so I've generator's come'n in from the Bazar all weekend. I round'd up bout 6 dead one's for part's.
so far I've been able to get em all go'n but I'm run'n out parts now !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
01-31-2012, 08:17 PM | #16 |
01-31-2012, 09:47 PM | #17 |
got my motor stabbed in this weekend... but have to pull it back out =/ oil pan is on the ground lol looks like i need a camaro pan.
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy |
01-31-2012, 09:59 PM | #18 |
Lots of good projects going on. I swapped out my old leaky radiator and put in a nice 4 core, and swapped out my old leaky gas tank for a good one. No more coolant on the floor and no more stinky gas smelling garage.
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
01-31-2012, 10:26 PM | #19 |
Right in front of you.
Been workin' on my T......
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
02-01-2012, 12:19 AM | #20 |
completely gutted my passenger door cleaned it up and painted the inside. ill tackle the outside tomorrow and hang it soon.
02-01-2012, 02:49 AM | #21 | |
Posted via Mobile Device Posted via Mobile Device |
02-01-2012, 11:29 AM | #22 |
got cab painted and mounted...
81 C10 LS3/6L80 - frame off - in progress |
