Old 04-28-2003, 07:03 PM   #1
BobM
700R4 with Rochester QuadraJet Carb Combination
Anyone with the 700R4 tranny and Rochester QuadraJet carb combination...what did you use for a TV cable & throttle cable bracket? Having trouble getting everything working together properly. Pictures would be helpful.
BobM is offline   Reply With Quote
Old 04-28-2003, 07:43 PM   #2
Project1970
14.1 @ 96MPH
Project1970's Avatar
No pics of mine, sorry...but I started off with a bracket for an '80s GM truck, cutting most of it off (has holes for a decent amount of stuff...) and the TV cable for the same. The vehicle source is honestly not terribly important, seeing as a 700R4 behind a given engine is going to need the same length TV cable whether it's in a Corvette or a Suburban, heh...
Take a look at the post on the FAQ board, one of the links in there has some really good info on how to set your TV up properly. http://67-72chevytrucks.com/vboard/s...threadid=33266
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-28-2003, 09:07 PM   #3
bigvinnie
bigvinnie's Avatar
I've got that setup, got the bracket from Summit racing, check their website.... www.summitracing.com
I'll see if I can post a pic later tonite....
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 04-28-2003, 09:21 PM   #4
Don Smith
I used P/N 25515598 Throttle valve cable and P/N 22504927 Bracket . The bracket bolts to the two back carb. bolts and has the cut outs for the T.V. cable and the throttle cable. I had to elongate holes in bracket but it works good and looks factory. Both parts are still available from GM.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 04-29-2003, 11:00 AM   #5
ckhd
ckhd's Avatar
I used the kit from Bowtie Overdrives. You have to have the right Q-jet... They make a custom bracket for about 3 different types of linkage.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 04-29-2003, 11:45 AM   #6
Low69CST
If you have access to a mid 80's chevy truck you can look at that. They have 700's w/ quadrajets
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-29-2003, 07:17 PM   #7
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I'm running a 327/700r4 combo & I tried the summit brackey but it flexed too much at full throttle preventing down shift... I snagged a bracket from a mid '80ies caprice & it works tip-top. The cable i used came from an '84 camaro 305/700r4 combo. To run the lock-up i used the painless wireing kit & it too works excellent. sorry but i have no digi cam...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 04-29-2003, 10:12 PM   #8
bigvinnie
bigvinnie's Avatar
the one I got from summit is beefy as hell and definitely won't bend... they must offer more than one style/brand....
72 Stepside Project
Old 04-29-2003, 10:15 PM   #9
passthebuck
ya bigvinnie u r probally right- the one i got was all adjustable & stuff... = a sad piece
passthebuck
#5642
