01-30-2012, 02:38 AM | #1 |
Scrapper 1
1967-70 rear ends to 5 lug 1971-72 rear end
can i make a 1967--70 12 bolt or 10 bolt chevy rear end into a 5 lug or convert a 5 lug into a 6 lug buy using the different years of axles if you can Private message me so i can get the answer thanks
01-30-2012, 02:47 AM | #2 |
Re: 1967-70 rear ends to 5 lug 1971-72 rear end
axles are not the same length
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
01-30-2012, 11:06 AM | #3 |
You can get aftermarket swap axles & use 71-72 drums. Aftermarket axles will be stronger than originals & have zero bearing wear vs 40yrs of wear.
01-30-2012, 12:55 PM | #4 |
Never Ending Projects
Agree with Scoti. Did this on my first '68. Used aftermarket axles that were 5 lug but for the narrower rear axle and used '71-'72 drums on the stock brakes. Worked great. Other option is to swap in a '71-'72 axle or a '73 and later but you have to weld on saddles for the trailing arms and weld or use an aftermarket track bar.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-31-2012, 08:40 PM | #5 |
I had my axles and drums on my 68 redrilled to 5x5 for $100 at a driveline shop.
