Problem Starting My 86 Chevy
I went to start my truck to goto work, and when I turned the ignition to start the engine it just "clicked" once. The gauges worked, but it just wouldn't start... What could the problem be?
![]() Posted via Mobile Device
-Samuel "Knowledge Is Power" |
Re: Problem Starting My 86 Chevy
Starter solenoid, battery terminals, loose connections, bad ground, bad starter
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
If the starter solenoid is bad, do I need to buy a whole new solenoid.
And bad ground??? Ground to what? Thank you? Posted via Mobile Device
try crossing the starter, they will help eliminate some possibilities
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
78K & 79C Jimmys
any other power?
meter the batt when you go to start...how low does it go
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Ok guys, I found the problem... GROUND WIRE!!!! Wtf. Anyways I had autozone check my battery & starter, and both were good. So I looked under the hood to inspect the connection, and my ground wire was VERY loose. So after I installed the starter I moved the ground wire and it started to crank the engine... Did I connect the starter wrong when I reinstalled it? So when I took the starter out I think I put the hot wire on first... All I know is when the ground wire hits the alternator is cranks even though there is no key in the ignition... What did I do wrong?
78K & 79C Jimmys
the batt + pos cable is prob twisted and hitting the purple start wire
