01-30-2012, 12:17 PM | #1 |
Disc brakes on my 66 GMC
I picked up a 66 GMC recently and it already had a power disc brake conversion done on it. I now would like to order dropped spindles for it but have no idea what conversion was done....71 spindles....73 or newer spindles...etc so before i ordered my new spindles what should I check to see what year of brakes it has on it?.....New to this Chevy/GMC truck thing...lol
01-30-2012, 01:30 PM | #2 |
Re: Disc brakes on my 66 GMC
some pix of your brakes and spindles would def help.
Posted via Mobile Device |
02-04-2012, 03:04 PM | #3 |
my brakes
02-04-2012, 06:42 PM | #4 |
Can you get a pic from farther back specifically of the a-arm bushings? The tab circled makes me think its a 71-72 set-up as that's how the lines were connected @ the front x-member.....
02-04-2012, 08:10 PM | #5 | |
67-72 parts collector,…
Like the 67-70 trucks had? 71-72's were on the front side.
02-04-2012, 08:55 PM | #6 |
This is correct.
02-04-2012, 09:12 PM | #7 |
So....should i just get the spindles for the 71 brakes?
02-04-2012, 09:27 PM | #8 |
You are going to have to figure out which balljoints and outer tie rods you have now.
That's the only way to know what spindle is currently on the truck. I assume the rotors are 1-1/4" wide and not 1" wide?
