Old 01-30-2012, 12:43 PM   #1
ckirk20603
ckirk20603's Avatar
Question 65 c10 lwb xmember/frame question
OK...noob question here.
This is my first truck rebuild. There is a cross member just below the front of the cab that is riveted to each frame rail and crosses just under the bellhousing of the tranny (which makes it impossible to pull the tranny from below) which is currently a small block w/ th400.
How structually important is this member and what if any suggestions on either drilling out the rivets and bolting back in or removing completely?
65 FLEETSIDE LWB
69 CHEVELLE SS
ckirk20603 is offline   Reply With Quote
Old 01-30-2012, 12:50 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 65 c10 lwb xmember/frame question
That crossmember was for the stock manual trans bell housing. It had rubber mounts (similar to engine mounts) so the whole engine/trans combo was held in with the front motor mounts and these bell housing mounts. The trans just hung out in the air.
Auto factory (I believe) did not have this crossmember and used the standard rear tranny crossmember and mount to hold everything up.
Likely your truck was orginally a manual trans truck. You can remove it and just use a rear tranny mount crossmember.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-30-2012, 12:59 PM   #3
ckirk20603
ckirk20603's Avatar
Great... thanks for the info chevy_mike!! I had a feeling it was for a different setup than what is in the truck now.
65 FLEETSIDE LWB
69 CHEVELLE SS
Old 01-31-2012, 01:16 AM   #4
Captainfab
60-66 Nut
I always recommend removing that crossmember when converting to an auto trans. When these trucks came from the factory with an auto trans, that bellhousing crossmember was not there.
Old 01-31-2012, 05:28 PM   #5
ckirk20603
ckirk20603's Avatar
Thanks captainfab. I'll be contacting you soon when I go to add a booster to this drum/drum brake truck.
65 FLEETSIDE LWB
69 CHEVELLE SS
