![]() Join Date: Dec 2009
need help from the refinishing guru's
I have a nice original saddle console that someone ignorant at the time (I wont say who :
Re: need help from the refinishing guru's
SEM vinyl dye comes in many colors in a rattle can
Fuzzy |
i'd try using laquer thinner on a rag// start in an inconspicuous place first
Yeah, I was thinking the same thing on the laquer thinner. Might try it this weekend. I'll probably still end up going over it with some of the vinyl dye, though, if nothing else to ensure a match with the door panels. Is there any secret to prepping for that stuff since this is more of an ABS plastic than a more pourous vinyl material? Obviously you dont want to use any typ of sand paper. Maybe wiping down with alcohol? Is the SEM dye something available at the auto body supply houses?
If you have access to some enamel reducer or mineral spirits I would try it first over the lacquer thinner because it not as strong. May take some more time but have better results. If you respray with sem dye then scuff with some scotch brite pads and clean it with some wax and grease remover first.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
BOHICA
put some brake fluid on the hard plastic parts. it will loosen it up and then you can brush it off with a stiff brush.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
I've had good results on the hard plastic painting it with regular enamel spray paint, if you can't get the old paint off.
Go to a parts store and find rubber bumper paint stripper, comes in a spray can.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
Now that something that I would have never thought of ! I'd really would like to have the original saddle finish when Im finished. I'll check around and see if I can find any of that.
