Old 01-30-2012, 03:39 PM   #1
sir_talk_alot
sir_talk_alot's Avatar
Speedo Cable Help Needed
ok guys, so digging into my truck this weekend, i realized the reason my speedometer doesnt work is the cable isnt hooked up. on further investigation, i figured out that the speedo cable hadnt been connected when the engine swap/trans swap my friend did because it was a powerglide and now its a t350. so i just assumed a new cable would fix the prob. oreillys and autozone were no help, they didnt have one for a 2wd. advanced has them, but he asked what length. thats my prob. he said that the new ones run about 3-4 inches longer than the old. my trucks is a 1970 custom 10 swb, its a short tail shaft turbo350, does anyone know what length cable i need? he named off a few lengths, 88 i think, 120 and 95 if i remember correctly. so i wanted to ask anyone who has messed with this what length i need. thanks guys
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 01-30-2012, 05:09 PM   #2
JRANGER
JRANGER's Avatar
Re: Speedo Cable Help Needed
im pretty sure i used the 88 on my 78 with a th350
I have my old cable at home...Ill try to measure it tonight
JRANGER is offline   Reply With Quote
Old 01-30-2012, 09:24 PM   #3
JRANGER
JRANGER's Avatar
Part # CA-3001 is the cable I got from O'Reilys for my 78 C15....I have a th350 Auto trans
Old 01-30-2012, 09:57 PM   #4
stomper
Junior Member
stomper's Avatar
I just bought one for my '71 and there was 1 choice for 1960-1972. It was listed as 70". Was way longer than the old one on the truck.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 01-30-2012, 10:01 PM   #5
JRANGER
JRANGER's Avatar
yeah i believe the one i listed is a 6ft
Old 01-30-2012, 10:13 PM   #6
rkn463
rkn463's Avatar
I went through a couple of different ones recently on a similar truck. One I had to return because the newer cables clipped on at the speedo instead of screwing on like our trucks do. Make sure what ever you get has screw on ends on both ends.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 01-30-2012, 10:15 PM   #7
JRANGER
JRANGER's Avatar
ok..the part # i gave you was for a clip on
Old 01-30-2012, 10:48 PM   #8
sir_talk_alot
so you guys think that a 88" or whatever 80 something inch cable should be ok?
-Mike-
Old 01-31-2012, 03:28 AM   #9
dmack91
dmack91's Avatar
While mine is a TH400, I can tell you that the cable I got was, I believe, around 80" and was way too long (like at least a foot too long).
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 01-31-2012, 07:45 AM   #10
cdowns
cdowns's Avatar
take a piece of rope or wire run it the way you'd run the speedo cable then measure wwhat is required
Old 01-31-2012, 06:52 PM   #11
rkn463
rkn463's Avatar
Better too long than too short... in so many aspects of life
