Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 01-30-2012, 05:50 PM   #1
American Pastimes
American Pastimes's Avatar
Ridetech Special
Guys for the Month of Feb. we are going to run a 10% off special on all Ridetech products and a free Ridetech T with all orders over 100.00!
63-72 Ridetech Level 1 kit
$1710.00 plus shipping
The Level 1 system offers a more economical solution to gain the advantage ofriding on air. With the upgrade options, this system can be equipped for anyperformance level. The front CoolRide system for the C-10 is a simple bolt-on installthat relocates the shocks to the outside of the factory control arms. The air springscome complete with brackets and hardware for proper mounting.A CoolRide rear kit also includes all hardware and uses the OEM control arms.The 3 gallon compressor system provides 4 way independent control with the useof RidePro valve body. It comes with easy to use analog gauges andelectronic switches for accurate control.
63-72 Ridetech Level 2 kit
$5220.00 plus shipping
The Level 2 system adds our very popular STRONGARM™ tubular control arms. This is a great way to take your vintage truck and give it modern handling. The front CoolRide® features upper and lower STRONGARMS® that provide a simple bolt-on to fix those old worn out factory units. The rear STRONGARM™ system is simply the best bolt in c-notch available for these trucks. It provides significantly more travel while retaining the strength needed to really haul. The 3 gallon RidePro®e3 compressor system provides 4 way digital control. It allows 3 system air pressure presets to provide accurate adjustments with the touch of just one button.
63-70 Ridetech Level 3 kit
$7605.00 plus shipping
If you want it all from your classic truck, this is the kit that can deliver. Smooth luxury ride, full use for hauling and load carrying, and a real hotrod on the track. This system delivers in every case. Our "Street Challenge" system includes the best of every option we have to offer. Upgrades like StrongArms, MuscleBars, and the RidePROe3 control system are included.
Lowers Your Truck's Ride Height
Ride height is where your truck should be driven at - you can expect be able to lower your vehicle 2 to 3 inches further when not being driven by deflating the air springs below the ride height pressure.
1.Lowers Front Ride Height from OEM by 4-5"
2.Lowers Front Ride Height from OEM by 5-6"
Improves Ride Quality
Since the air springs can be adjusted to nearly infinite spring rate, perfectly accommodating the weight of your truck, your truck will ride better than ever. Even when you are hauling a load!
The triple adjustable aluminum shocks included in the Level 3 package provide you with tuning options to control the compression and rebound valving so you can dial in your truck for corner carving or smooth cruising... or anywhere in between.
Improves Handling
With optimized suspension geometry provided by the StrongArms, the adjustability of the air springs, and triple adjustable shocks, and the upgraded MuscleBars (swaybars) don't be surprised when your "ol-truck" can hold the road with modern sports sedans.
Dependable
We build our systems with a goal of improving OEM standards, which includes the durability and safety margins. Our suspension components are built strong and durable enough for everyday use. We're talking six digit mileage - EASY. We know, because we have multiple trucks in our fleet that have logged over a quarter million miles on our systems (some pulling 40+ foot tailors).
Complete Package
Yep, it is everything you need. This Level 3 kit includes all the hardware, bolts / nuts etc... to get your truck riding on air. We've picked out our best stuff, you know it is all going to work together perfectly.
RideTech C10 Suspension Design
Front Features:
1.Built additional caster into the arm so that the car drivers better, especially at higher speeds.
2.Switch from greased metal bushings to rubber bushings.
Rear Features
1.The front trailing arm crossmember is designed to allow the exhaust to be run through it rather than under it providing additional ground clearance.
2.The panhard bar mount on the rearend has been lowered to optimize the bar angle for the lowered height. This helps keep the rearend centered in the truck.
3.The C-notches are included with the rear airbar kit and FIT the frame rail.
4.With the airbar setup the driveline angles have been optimized for the lowered height.
5.The Airbar kit includes new trailing arms for the guys with trailing arms that have rusted out.
6.The panhard is adjustable so you can optimize your tire clearance at the new lowered height.
Musclebar sway bar
$360.00 plus shipping
Lets face it... the most overlooked suspension component is also one of the most important. The magic you could be missing in your suspension may be nothing more than simply adding or upgrading your sway bar(s)!
The New MUSCLEbar™ sway bars were developed specifically for lowered vehicles and will greatly enhance the cornering performance of your car or truck. (Not to mention they'll also make some vehicles safer at the speeds we travel on today's interstate highways.)
Increased bar diameters, polyurethane bushings, and appropriate attachment links all add up to a sway bar package that is designed to work correctly with your lowered car or truck and your aggressive driving style.
This kit also includes Posi-Link end links.
•Improves range of motion & eliminates binding
•Strong design prevents deformation and failure
•Positive transfer of motion through swaybar
•OEM high performance quality
We are also offering specials on all there compressor systems, accesories, and hardware!!!!
American Pastimes is offline
Old 02-26-2012, 10:01 PM   #2
SBC
SBC's Avatar
Re: Ridetech Special
What would it cost for an Airpod system?
SBC is offline
Old 02-27-2012, 02:37 PM   #3
American Pastimes
Hi, I will work on that for you and get you a price.
Old 02-28-2012, 06:29 PM   #4
American Pastimes
airpod unit 3031400, 4000 series w/ 3 gal tank single comp $1,800.00 -10% off 1620.00 (FREE S&H)
airpod unit 30314100, 4100 series w/ 5 gal air tank & 2 comps $2,000.00 -10% off 1,800.00 (FREE S&H)
OPTIONAL COVER $100.00
(OPTIONAL) EXTERNAL LEVEL SENSORS $500.00 -10% $450.00
Let me know whatcha think, you can call me @ the shop ask for jay
Old 03-03-2012, 02:29 PM   #5
suspect
suspect's Avatar
do you offer the 63-72 ridetech level 1 kit with the e3 digital control? if you do, can i get a price?
thank you, daniel
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline
Old 03-03-2012, 02:39 PM   #6
SBC
SBC's Avatar
I recently called Jay at American Pastimes to order my ride tech products. Im sure they will have what your looking for at a great price! Looking forward to doing more business with them in the future.
SBC is offline
Old 03-26-2012, 12:55 PM   #7
American Pastimes
We still have Ridetech on Sale....please PM us if you would like more info.
Old 05-03-2012, 06:59 PM   #8
American Pastimes
Old 11-28-2012, 07:43 PM   #9
American Pastimes
Ttt
Old 05-12-2013, 09:43 PM   #10
cardreams
is the sale still on ?? looking for lavel 1 for my 72 c-10
cardreams is offline
Old 05-15-2013, 04:58 PM   #11
American Pastimes
YES IT IS
Old 06-24-2013, 05:30 PM   #12
American Pastimes
Ttt
Old 09-04-2013, 07:37 PM   #13
American Pastimes
Sale, sale, sale, sale,
Old 09-06-2013, 11:44 PM   #14
bobbymoss
how much for muscle bar for 67-73 chevy c10 with shipping to 70538
bobbymoss is offline
Old 09-10-2013, 05:43 PM   #15
bobbymoss
quote on muscle bar swaybar for 67-72 chevy c10 shipped to 70538 Thanks
Old 09-11-2013, 09:11 AM   #16
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
What are the prices on the new coil over level 2 and 3 setups?
chevyguy_72 is offline
Old 10-01-2013, 05:36 PM   #17
EPS3
What is your price on the new C10 front coilover system? See attached.
I'm interested in buying with the coilovers.
EPS3 is offline
Closed Thread
