01-30-2012, 07:10 PM | #1 |
Please, help me with advice...
Ok, had truck in the shop for a few months, for welding gearbox back to the frame.
Also, found out that the shop owner has a ‘76 like mine. Long stony short, need advice/opinions. I don’t know how to link photos, so if you’d please go to www.photobucket.com my user name is, c10fan_ As always thanks for your advice, I really appreciate it. So, three quick questions, 1. Does this look like some sort of sabotage to my frame or a trans swap? 2. Do the u-joints look to be new/changed? 3. How do I reconnect the driver’s tank, currently hose is cut off with bolt in it. |
01-30-2012, 07:23 PM | #2 |
#16876
Re: Please, help me with advice...
Do you have a direct link?
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
01-30-2012, 07:56 PM | #3 |
01-30-2012, 08:08 PM | #4 |
What Hump?
I uploaded the pictures for you.
The u-joints appear new but I'm not sure they are installed properly. I think the retaining clips hold the bearing cups in place were not installed, they appear to need pressed in more. Guys is there another type of clip. Tom
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
01-30-2012, 09:19 PM | #5 | |
All Texas mebers stay away from Larue Automotive in Houston, Texas |
01-30-2012, 09:36 PM | #6 |
78K & 79C Jimmys
not sure why a garage would cut the support like that
i think you have inner clips
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-30-2012, 09:40 PM | #7 | |
2. Your u-joints look new and you have the inner c-clips, looks OK. But the yoke doesnt seem deep enough in the trans. 3. It looks to me that your dual tank selector valve has been by passed most likely because it or the switch isnt working properly. Basicaly you have three lines coming from the motor and three lines coming from each tank wich converge at the selector valve. Each set of three lines are a different size. Im assuming that the selector valve isnt working so you will need to pic the one tank you want to run so you can hook it up direct. One of the three lines will be "T-ed" with the other tank, leave that one alone. Connect the other two to the same size line from motor to the same size lines from the left tank. I hope this makes sence.
John 82 Chevy Silverado 350ci/TH350 |
01-30-2012, 09:40 PM | #8 |
The One And Only !!!
No other style for that drive shaft, I see one clip but make sure all four clips are in place. That's crazy with the fuel line and cross member, And.... What's all that silver shaving stuff all over ?
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
01-31-2012, 07:13 PM | #9 | |
I wanted them to just fix the gas gauge and make it read accurate, it hasn't worked right since I bought the truck. Thanks to everyone for the great information. |
01-31-2012, 07:18 PM | #10 |
Its past crazy its just downright damn evil without a cause. I thought maybe he switched my trans with his, because like I said he has a '76. Thanks, though.
01-31-2012, 08:23 PM | #11 |
Sorry to hear about all your misfortune with this place.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
