01-30-2012, 07:51 PM | #1 |
H2 wheels with GMC center caps?
Since the 8-lug wheel choice is somewhat limited, of the options available I think I prefer the chrome H2 wheels that I've seen. Those who have used them apparently use a centercap with the Bowtie on them, but I have a GMC (1970 2500 3/4-ton).
So, two questions: 1) Is that centercap I see actually the Hummer one or is it from a Silverado? 2) Is there a good GMC centercap that I can get from a later application that will work? Thanks! Dave |
01-30-2012, 07:58 PM | #2 |
Re: H2 wheels with GMC center caps?
All 99-current 3/4 ton caps will work with the right lugnuts. The chevy and gmc centers are the same minus the decal in the middle.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
01-30-2012, 08:22 PM | #3 |
Most of this is ture. 2011 the lug pattern changed so dont get those and there is a small difference in the center caps between steel and aluminum wheel. The ones on aluminum wheels have 4 small studs that have to be cut off to fix on the hummer wheels.
01-30-2012, 09:35 PM | #4 |
E.H.F.D Engine #2
I put those wheels on the '03 2500 i just sold. I got the center caps off ebay brand new for under $100. The GMC caps are exactly the same, except for the logo of course. I think the H2 wheels look great with those caps, and would love to see them on a 67-72
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
01-30-2012, 09:42 PM | #5 |
The 88-98 style work,too,and are a more attractive design IMO.
01-30-2012, 09:44 PM | #6 |
Real Projects never die
One of the guys on ck5 found out those centers dont work on the hummer special edition wheels.
http://coloradok5.com/forums/showthr...hlight=special Might not be able to see pics without a membership.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
01-30-2012, 09:49 PM | #7 |
Ridin' Dirty
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
01-30-2012, 09:58 PM | #8 |
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
01-30-2012, 10:17 PM | #9 |
What size are the Hummer wheels? They look awesome.
-Richard
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
01-30-2012, 10:21 PM | #10 |
Ridin' Dirty
17x8.5
01-30-2012, 10:27 PM | #11 |
01-30-2012, 10:27 PM | #12 |
Ridin' Dirty
Kinda small pic, if you squint just right, they look like they might be H2's on there..
01-30-2012, 10:30 PM | #13 |
Ridin' Dirty
01-31-2012, 12:02 AM | #14 | |
1) Do NOT expect that all of the caps from the last decade will fit. The ONLY cap that I know will fit into the H2 wheel recess is the one used on the 2500HDs from 2001-2006/2007 Classic Chevys and GMCs WITH THE ALUMINUM WHEEL OPTION. I also THINK this cap was used on the aluminum wheels during the first couple years of the current generation. This cap fits perfectly into the recess, and I did not need to make any modifications other than use SAE dual thread lugnuts. I can say with absolute certainty that the van caps (I think for the steel wheels with the chrome plate or overlay) which have a nearly identical appearance and the steel wheel caps WILL NOT fit the recess. I tried a set of these first. To differentiate these 2 cap styles...The aluminum wheel caps have buldges around the circumference at each lug location and fit, and the van caps are smooth around the circumference. The dually caps are way too big, even the rears. 2) Refer to this thread for my description of fitment and lug nut choices. http://67-72chevytrucks.com/vboard/s...d.php?t=504413 I don't recall the offset, etc. and have not checked clearance other than as noted in this thread. My truck is currently in the state shown in the picture. Note that my truck is a 69 with front drums. I read somewhere on this forum that disc brakes place the wheel mounting surface farther outboard. |
01-31-2012, 10:25 PM | #15 |
Roto Reuter thats the name...
As I said before, FirstOwner69, those wheels are killer! First will be my front disc conversion, but in the meantime I will keep my eyes open for a set of those. Chrome definitely look better than aluminum.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
02-17-2012, 11:47 AM | #16 | |
17" Dia. 8-lug X 6.5" BC 4-1/2" Hub Dia. 8-1/2" width (9-3/4" overall rim width) 5-1/2" Backspace which translates to 3/4" (19 mm) positive offset I purchased OEM Chevy 16" center caps P/N 9597169 / 9597170 which are 2001-2007. They fit perfectly on the H2 rims with no mods required. I need to buy conversion lug nuts next. I am not sure about my tires. I want to run a bigger tire, like 285/70-17. I just want to be sure they will fit without any clearance problems.
11-04-2014, 05:39 PM | #17 | |
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
11-04-2014, 06:15 PM | #18 |
I bought the center caps on Ebay. Do a search and you should find them. I can't recall the seller. I also bought the conversion lug nuts on Ebay. I think I used the Lug Nut King for those. Good luck. Keep me posted on how you make out.
11-04-2014, 06:17 PM | #19 |
For sure. I am excited, just found a set on the local craigslist for $400. Probably get him down to at least $350 for a set in chrome. Also, I just did an eBay search and just wanted to make sure I didnt get screwed with some cheap plated center cap.
11-04-2014, 06:17 PM | #20 |
Chevy or GMC? What rear end? Below is what I ended up with. 2001-2007 aluminum wheel caps modified so the centers resemble the hubcap centers. The steel wheel caps that look almost identical will not fit the wheel recess. The Dana axle will present fitment problems due to how far the hub projects. I think Davepl ended up using spacers.
11-04-2014, 06:20 PM | #21 | |
From what I can tell, this should be straight forward like Dan's, right?
11-04-2014, 06:21 PM | #22 |
PS. I love the custom blue bowtie on your caps.
11-04-2014, 06:23 PM | #23 |
There are a lot of non-chrome H2 wheels that have been chrome plated. It's easy to spot them.
11-04-2014, 06:24 PM | #24 |
11-04-2014, 06:24 PM | #25 | |
I just hate buying off eBay sometimes...if you know what I mean.
