Old 04-28-2003, 09:47 PM   #1
Orence1
Orence1's Avatar
Silverado Seats
Some of you asked for more pictures of the late model Silverado seats. Here you go.
Orence1 is offline   Reply With Quote
Old 04-28-2003, 09:48 PM   #2
Orence1
Orence1's Avatar
Passenger side view
Old 04-28-2003, 09:50 PM   #3
Orence1
Orence1's Avatar
Seat base view
Old 04-28-2003, 09:54 PM   #4
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
Those fit in there real nice!
Where did you find them, and how much
did you have to pay (If you dont mind)?
Are those grey, or a shade of blue?
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 04-28-2003, 10:03 PM   #5
Lucky59
Do you feel Lucky...?
Lucky59's Avatar
Thats what I originally wanted for my 59, I couldnt find a set, and if I did they wouldnt be cheap. I did however find awesome seats out of a Pontiac that are perfect... and for only 15 bucks. BTW they look real sharp in ur truck.
Lucky
1959 Chevy Shortbox Stepside
1969 Chevy Custom C/10
1991 S-10 Blazer Sport
2003 Dodge SX2.0 R/T
2001 Mountain Cat 800 LE
Lucky59 is offline   Reply With Quote
Old 04-28-2003, 10:15 PM   #6
Solarus1981
Do those bolt up to the stock seat mounting points? If not, what did you have to change?
'67 LWB C-10, 406 cid th350, dunno what rear end
Looking to rent a house in Puget Sound area, anyone have one?
Solarus1981 is offline   Reply With Quote
Old 04-28-2003, 11:57 PM   #7
Orence1
Orence1's Avatar
Dano,
I paid $500 for the set at Walt & Verns Truck parts in Buckley, WA.
Solarus,
I'll let me good friend Stllookn answer that question as he did most of the work on the installation:
To install those seats you must remove all the existing mounting brackets...die grinder on the rivet heads works great for this. Align, mark and drill new holes. The rear outboard mounting point needs to be shimmed up about 1/4 inch...a couple of thick flatwashers should do. The other mounting points may need about one washer each to ensure the slides do not hangup on your carpet, depending how thick it is.
Old 04-28-2003, 11:58 PM   #8
Orence1
Orence1's Avatar
Dano,
Sorry, I forgot to answer your other question. They are a dark charcoal grey.
Old 04-29-2003, 12:11 AM   #9
DanoDMano
DanoDMano's Avatar
Those look real nice in your truck, I searched the loft
at Walt and Verns myself, but man were they expensive!!
I think I am settling for a set of e-bay Lexus Black Heated
buckets, and then adding a late model trans Am center console!
That is my hope anyway!
Thanks for the Info!!
Power Locks,
Truck Photos
Old 04-29-2003, 01:07 AM   #10
StingRay
StingRay's Avatar
Sweet lookin seat. I want one. I like it. Since Stllookn put em in I already know it's done right but others need to condsider with that kind of seat having the integral belts that the mounting hardware is critical. All of the loads in an accident will translate through to the floor mounting and if it's not done right the occupants and the entire seat can come dislodged as a unit with the mountings tearing right through the floor. Some engineering thought needs to be put into to many of the kinds of modifications that many of us make to our trucks.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-29-2003, 01:13 AM   #11
DanoDMano
DanoDMano's Avatar
A Valid point.
If bolting ours directly to the floor is secure, then having a bracket made that also bolts right up to the existing holes would be okay.
I am going to have some real beefy brackets made that will both elevate the seat, and maintain the stock strength!!
Good advice!!
Power Locks,
Truck Photos
Old 04-29-2003, 01:58 AM   #12
JHickson6
I Love This Stuff!
JHickson6's Avatar
Hey Orence1 do you get much tilt out of those seats? Do you have any rough measurements of the space to the back of the cab at the top and bottom of the seats?
Thanks Jared
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 04-29-2003, 02:07 AM   #13
67_SS396
That looks great! Thanks for posting the pics, now I have an even better idea of how to go about it.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 04-29-2003, 02:51 AM   #14
beau396
I put a 60/40 split bench seat out of a 2000 'Burb in my '67. The seat sliders do not attatch to the floor. Each seat has four feet and the sliders mount between them and the seat. I drilled individual holes and tack welded 3/8 nuts onto 1/8 steel plates. Then I tacked the plates onto the underside of the cab to use as mounts for the seat bolts. It is a pretty burly setup and is much sturdier then the factory '67 bench setup. I plan on using seatbelts out of a '88-92 fullsize Chevy p/u but have not found a set yet in the color I want. If anybody is interested I will post pics.
'67 C10 short box fleet side wood bed small rear window frame off restoration. 396BB,Th400, ps, pwr disc 5 lug, posi 3.07, 2000 Suburban 60/40 pwr seats, 2.5" front drop 4" rear, powder coated running gear.
beau396 is offline   Reply With Quote
Old 04-29-2003, 03:20 PM   #15
Charlie Coleman
Charlie Coleman's Avatar
I may have a pair out of a 99' - 02' Silverado LS available. They are charcoal grey, 6 way power buckets, and very clean.....no wear what so ever. A fellow board member has first shot, but if he doesn't take them, they will be available in the Denver area. They are taking up too much space in the garage, besides I am selling the house and don't want to move them.
$300 obo for the pair.
If anyone is interested, contact me later this week.
Charlie Coleman is offline   Reply With Quote
Old 04-29-2003, 04:54 PM   #16
dons72
dons72's Avatar
thanks for the picks I might have to try this if I can't find some buckets.
72 cheyenne super
dons72 is offline   Reply With Quote
Old 04-29-2003, 07:44 PM   #17
StingRay
StingRay's Avatar
Danodmano. Stock seat mounting points only have to carry the load of the seat itself in an accident. You are restrained by the belts(for that matter in a frontal collision even some of the seat load is carried by you and the seat belt) that have their own very substantial mounting points.
With that newer seat that has integral belts both the seat and the individuals in the seat would need to be held in place by the seat anchor points. Not a good idea. These kinds of loads can be very large and far beyond the design limitations of the original seat mounting points. If anything new bracketry should include fixture points into the seat belt mounting points in the floor...all or most of them.
Just for clarity so that you don't think I am trying to be a know it all, I am an Engineering Technologist that works for an RV manufacturer and one of my areas of responsibility is working with seat/seatbelt suppliers on just these kinds of applications. I only provide my opinions here as you and your loved ones could be at significant risk of injury or death in an accident if serious engineering type consideration is not given to the types of modifications you make to your seating and seat belts.
Canada
Old 04-29-2003, 07:57 PM   #18
DanoDMano
DanoDMano's Avatar
Hey I appreciate the advice. Whenever I need advice on truck matters, this is where I go!!
I will make sure that they are secure when I Install them, and knowing now about the integrated belts, I will make sure it is done right!
Power Locks,
Truck Photos
