01-30-2012, 09:26 PM | #1 |
Gas tank Filler locations/options?
I know the re-locating of the gas tank has been beat to death so I wont even bring that up.
BUT I have decided to do just that and am using a brand new re-pop 55 chevy passenger car tank. I hate the idea of mounting the filler neck/fuel cap in the bed and I think I want to route it out the rear of the drivers side fender (I have a stepper) but am open to ideas. What do you guys think? Out the rear of the stepside fender or out the side of the fender to the rear of the tire? Or any other suggestions? Pictures would be nice. Thanks, |
01-30-2012, 09:58 PM | #2 |
Who Me?
Re: Gas tank Filler locations/options?
Im good with the idea. Do you plan to use a stock style of cap sticking out or a later model flush mount door?
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
01-30-2012, 11:17 PM | #3 | |
02-02-2012, 09:58 PM | #4 |
I like the idea of the door and I have seen them on the back side of the fender and on the outside of the fender.
Was wondering what style door would work the best and what all parts I needed to grab from the salvage yard when I go to cut one out? |
02-03-2012, 12:13 AM | #5 |
What I plan on doing to mine is like the old 50's Bel Airs and mounting the filler behind one of the tail lights. I think I have seen pics of someone else doing it that way on here but don't totally remember.
02-03-2012, 12:28 AM | #6 |
I got my door from a ranger. not a stepper but same idea
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
02-03-2012, 09:26 AM | #7 |
Thats the idea i'm looking at.
Did the salvage yard let you cut that door out or did you get it someplace else? What other parts did you have to get to make it work? |
02-03-2012, 09:29 AM | #8 | |
Actually like the license plate idea but I hear that the tank can be too slow to fill if located incorrectly. |
02-03-2012, 12:20 PM | #9 |
I too would like to know what I can do, I dont get the best traction and I figure any weight in the back is good, no to mention that the tank behind the seats lets out smells, nothing bad, but when others ride in my truck, they can smell it, I guess I am use to it
I would like to mount mine in the far back right under the back of the bed with the cap pointing out to the bottom of the tail gate |
02-03-2012, 12:20 PM | #10 |
It may not be what you like but it sure is easy and works very well. SOme times it is easier to not and re invent the wheel.
62 long box with a little SBC http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
02-03-2012, 12:35 PM | #11 |
I like that idea too, where did you get that tank?
02-03-2012, 12:37 PM | #12 |
I have a X frame so that is a custom made tank, however I see that CCP or one of those places now sells a bolt in unit,
02-03-2012, 01:14 PM | #13 | |
thanks in advance |
02-03-2012, 01:43 PM | #14 |
02-03-2012, 01:47 PM | #15 |
performance parts online
02-03-2012, 01:48 PM | #16 |
GMR could you pm or email or post the specs for your tank? I'm ordering a custom one soon and I'd like to compare measurements vs what I've come up with, I havent found alot of info on xframes here and I don't want to screw it up lol.
Thanks |
02-03-2012, 02:34 PM | #18 | ||
you can get those flush caps at marine surplus for about 1/10th of what hotrod and motorcycle shops sell them for. I dont like the idea of a bed floor filler because its a fiddly chore to fill it even with the tailgate down and the wood area around is bound to get dings and splashes. but hey humpty said doowhatchoolyke
02-03-2012, 04:47 PM | #19 |
Well you dont have to use that marine filler cap. Plent others out there that you could use. As for the wood, I am not using spar varnish on mine, It is getting sikkens clear, UV proctection, tough as nails against just about anythig you can spill on it. Heck you could even buff out marks in it ... Not that I would but still the same it can be done.
I know of several that where done this way vs varnish, years later in the AZ sun the clear is still holding like the day it was new, cannot say that about the spar products.
02-03-2012, 10:36 PM | #20 |
60-66 Nut
We have a board vendor that builds custom fuel tanks as well as regular production units.
http://www.67-72chevytrucks.com/vboa...d.php?t=362307
02-24-2012, 12:26 AM | #21 |
Did you have to cut the marine filler neck down to be able to attach it to the filler neck welded to your tank. I put in a 78 blazer tank in my 65 and the top of the tank touches the bottom of my bed cross sills and the filler neck thats being welded in it by a local shop will be sticking out 1 1/2". From my measurements, there will only be a total 3" of space available from the top of my tank to the top side of my bed wood. I see that the marine filler is 3" long (I don't have it yet) and with my tank spout being an 1 1/2", for a total of 4 1/2", it's too long...(not gonna fit), so I am assuming I should just be able to cut the marine filler off to about 1 1/2" +/- and join the two pieces together with a hose and be done..right? OR did I just screw it all up??? It seems logical, but who knows I just winged it on the install....lol.Should I have done something differently or is this normaly what needs to be done? I really hope this makes sense and that I tagged the picture you posted correctly.
Opportunity usually comes disguised....As hard work!!! |
02-24-2012, 01:23 AM | #22 |
Senior Enthusiast
Posts # 11 & 22 show how I originally did mine on the inside bed wall, hidden under the stepside fender. It was a great idea, but I goofed on the tight angle at the fuel tank:
http://67-72chevytrucks.com/vboard/s...light=gas+tank Post number 50 shows the current configuration with an aircraft cap. It’s located very close to the left rear corner of the bed for convenience at the gas pump, and for making it easier to access I there’s a bunch of stuff in the bed. |
02-24-2012, 10:34 AM | #23 |
No I did not cut down anything at all. Other than a chunk of hose.
02-24-2012, 12:10 PM | #24 | |
02-25-2012, 12:24 AM | #25 |
60-66 Nut
Cool
Let us know how everything works out once you get it installed.
